vhdl array question
I need to generate select lines for 128 multiplexors.  I thought of creating an array [muxsel(127 downto 0)].  Based on an input value of 0 to 127 I would then set muxsel bits appropriately; example if I receieved and input value of 15 I would set
 muxsel( 127 downto 15 )=>1,  others =>0.
I can't seem to figure out how to place a signal / variable into the array, example
muxsel <= (127 downto X => '0', others => '1');
After some research my issues may be related to complex constructs that Vivado doesn't yet support:
http://www.xilinx.com/support/answers/52302.html
Does anyone have suggestions of a work around if the problem is the Vivado sysnthesis engine?  IIt appears this has been an issue for a bit:
https://forums.xilinx.com/t5/Synthesis/Vivado-2014-2-Synth-8-561-range-expression-could-not-be-resolved/td-p/562555
Participant pete_128
Re: vhdl array question
signal input : std_logic_vector(6 downto 0); --your input signal
signal output : std_logic_vector(127 downto 0); --your one-hot outputs
process(input) is begin
    outputs <= (others => '0');
    for I in 0 to 127 loop
        if I = conv_integer(input) then
            outputs(I) = '1';
        end if;
    end loop;
end process;
Something like this might work. You coudl try ditching the loop, and just use conv_integer on the input to index into the array directly, but synthesis has barfed on me for that in the past (and gives similar errors to the one you linked in the AR).
in one of the post it was suggested to write a case statement to work around this Vivado deficiency.  In the middle of that now.  On a small scale it worked now I have to expand on it quite a bit.
