vivado 2018.2 much slower than 2017.2 (at least for small designs)
I see much longer elapsed times for vivado 2018.2 compared to 2017.2 on a Linux system. I use Ubuntu 2016.04 LTS, thus a supported system. I have cross checked on a Debian Wheezy system, with very compatible trends.
The issue is visible in synthesis, implementation and bit stream generation, so simply post it in the synthesis section of the forum.
It's most pronounced for small designs, the elapsed time shown in the GUI is
             2017.2    2018.2
    synth_1    0:51      1:31
    impl_1     1:04      2:57
so both synthesis step as well as implementation are much slower in 2018.2 than they are in 2017.2 .
Two example projects, with identical sources, ran on the same CPU, are attached.
Usually I use a fully scripted implementation flow. The elapsed times for a somewhat larger design, but still small by todays standards, for synthesis only, synthesis and implementation, and full synthesis+implementation+bitgen are
                      2017.2    2018.2
    synth            1m08.6s   2m16.6s
    synth+impl       3m10.6s   6m56.1s
    synth+impl+bit   3m50.1s   9m16.1s
From this it's clear that all three steps are substantially slower.
When looking at a CPU monitor (like good old xosview) one immediately sees that for 2018.2 runs vivado uses a lot of system state time. In certain phases, which last for half a minute, one sees 75% system time. This is not observed for 2017.2. Needless to say that tests were done on an otherwise idle machine, and that no significant paging was visible.
I used pidstat to trace user and system state time and got for full synth+impl+bit runs
  very small design
    2017.1: usr:   136.07   sys:     6.36   tot:   142.43
    2018.2: usr:   180.85   sys:   190.21   tot:   371.06
  small design
    2017.1: usr:   492.83   sys:    19.99   tot:   512.82
    2018.2: usr:   853.77   sys:   224.00   tot:  1077.77
It is clearly visible that usr time slightly increases, and sys time explodes by more that an order of magnitude.
Last but not least I checked in which phases vivado 2018.2 behaves differently that vivado 2017.2
  --- synth step ---
    INFO: [Device 21-403] Loading part xc7a100tcsg324-1
      --> 75-80% system time
  --- impl step ---
    Starting Cache Timing Information Task
      --> 55-80% system time
    report writing
    INFO: [Timing 38-478] Restoring timing data from binary archive.
  --- bitgen ---
    INFO: [IP_Flow 19-2313] Loaded Vivado IP repository 'Vivado/2018.2/data/ip'.
      --> is simply idle for quite some time
From all the above the bottom line is
1. it seems that a very inefficient I/O library is used
       INFO: [Device 21-403] Loading part ...
2. it seems that vivado waits for something when loading the IP repository
The effects I've seen are quite drastic, and reproducible on two Linux systems (one being a supported Ubuntu 2016.04 LTS). So I wonder whether others have seen similar issues
Scholar drjohnsmith
Re: vivado 2018.2 much slower than 2017.2 (at least for small designs)
thats a fantastic set of tests, well done
Must admit I see small designs taking longer too,
   whilst large designs seem to be faster,
but that is all it was a feeling,
I'm looking forward to some xilinx input on this
Hi @drjohnsmith,
did you see this under Unix/Linux (if yes, which flavor), or under Windows ?
It be very interesting to understand whether this is a Unix/Linux integration issue, or a general one.
Cheers,   Walter
Scholar drjohnsmith
different companies I work for have various versions of widows and linux,
And as I said, its a feeling,
Generally, for vivado, Linux is faster than windows, windows 7 was faster than 10,
but the original test that were not done by me, are very interesting
I've done a little bit more research on this issue. I've tested two designs
  snhumaio     ~190 LUT;    ~160 Flops;    ~1% slice of 7a35 (Basys3)
  w11a        ~5700 LUT;   ~2400 Flops;   ~20% slice of 7a35 (Basys3)
so one 'null-design' and one small design, both for a Digilent Basys3 board on two systems
  sys1   Ubuntu 16.04 LTS;  dual core
  sys2   Debian 7; XEON quad core with hyperthreading
which both have Vivado versions from 2016.4 up to 2018.2 installed, and get as elapsed times for my scripted build flow (syn+imp+bit)
                 --  snhumanio --    -----  w11a -----
                    sys1     sys2       sys1      sys2
      2016.4     3m44.2s  2m34.2s    8m00.0s   5m00.5s
      2017.1     3m28.5s  2m19.6s    8m00.6s   4m50.9s
      2017.2     3m43.6s     n/a     8m35.9s      n/a
      2017.3        n/a   6m12.1s       n/a    9m09.1s
      2017.4     9m36.5s  7m17.7s   15m14.7s  10m10.1s
      2018.1     9m30.4s  7m47.8s   14m08.9s  10m20.5s
      2018.2     8m55.2s  7m19.3s   13m47.6s  10m01.8s
The snhumanio essentially measures general setup overhead, because there is little to compile or route.
From this is apparent that
  • the main performance drop came with the 2017.2 to 2017.3 transition
  • a second smaller drop came with 2017.4
  • while 2018.2 brought a mild improvement
As stated before, watching a process monitor, like xosview, shows for 2018.2
  • often extended periods of 75% system time
  • some times extended idle times
I used pipstat to trace this, and tried to visualize this with gnuplot. Four pictures are attached
which show the CPU utilization (in %) over time, red is system state time, green is user state time.
The transitions from synth to impl to bitgen phases are nicely visible.
It is striking that 2018.2 has extended times with about 75% system time, while 2017.1 shows only a very moderate system time fraction. The data for the pictures were taken on sys2, on an otherwise idle system, back-to-back in one session.
It be nice to hear from others whether they see similar effects. Some feedback from Xilinx is of course also much appreciated.
Hi @wfjmueller,
I am currently checking your testcase with Vivado 2018.3 internally. And i will get back to you with the outcomes. If the issue still persist we need to send it to the factory.
hemangd
hemangd
Don't forget to give kudos and accept it as solution if your issue gets resolved.
Hi @wfjmueller,
I have filed a CR (Change Request) on this issue. Let factory look into it and they may make necessary changes in upcoming versions of Vivado.
hemangd
hemangd
Scholar drjohnsmith
@hemangd
did your answers correlate ?
Hi @drjohnsmith,
Yes, 2018.3 and 2018.2 showed same results with high run time compared to 2017.2. Hence, a CR.
hemangd
hemangd
Hi @hemangd,
thanks for the statement. From this I conclude that the essentials of my observations could be reproduced. I'll flag this as 'solved' when I see the Vivado version which restores the pre-2017.3 performance.
Thanks again,   Walter
Not surprising. Software has become a code-and-stuff pile-up exercise. It has reached that point where faster clocks (not much faster nowadays) cannot cope with the global software overweight. Time for GPU makers making money until the next bottleneck. Look at android apps... how many can you stuff in a GB? They are lean. It's the opposite for PC apps: how many GB takes an app... Anyone sees why?
Hi @hemangd,
I've re-tested the cases described on 2018-09-01 with Vivado 2018.3, the measured execution times for a syn+imp+bit run were
                    sys1     sys2       sys1      sys2
      2018.3     4m32.2s  3m44.5s   12m01.7s   8m20.2s
Vivado 2018.3 is a bit faster than 2018.2, but still significantly slower than 2017.1 or 2017.2. I've also repeated the pipstat traces. Vivado 2018.3 does not longer show the excessive amount of system time seen
in 2018.2, see appended figures. However, there is still an hard to explain idle time of several 10 secconds at the end of the bitgen phase. This was also observed for 2018.2, but not for 2017.1.
Scholar drjohnsmith
your amazing ,
please tell us Xilinx have these test cases in the regression tests,
Voyager
Voyager
In the tests I did on one of my projects, you may see an substantial improvement on 2018.3 on both synthesis and implementation. Of course, your mileage may vary.
https://forums.xilinx.com/t5/Implementation/Implementation-time-is-reduced-in-2018-3-vs-2018-2/td-p/924314
https://forums.xilinx.com/t5/Synthesis/Synthesize-time-is-reduced-in-2018-3-vs-2018-2/td-p/924312
