cesarcf
Add extra delay without IDELAY primitive
I want to add a delay of ~4.5 ns to some differential inputs in Kintex US (Vivado 2018.1). I am using 4 IODELAY primitives in cascade mode (with a configuration of IDELAY-ODELAY-IDELAY-ODELAY) to achieve this delay. So far so good.
However, those IOBs that are placed on pin 0 of a "byte group" do not allow a cascade greater than 2 IODELAYs, because delay elements cannot go through the byte boundary. So, I need to add an extra delay in those pins to make up for the 2 IODELAYs I cannot implement.
My idea is to use a fixed delay as offset and make a fine-tuning with the 2 remaining IODELAYs.
Which is the best way to add that "extra delay" as offset? There is any constraint to determine the delay of a net, or using buffers/LUTs... to get a kind of deterministic delay value?
I also appreciate another suggestion. Thanks in advance!
Tags (2)
cesarcf
This is for receiving data at up to 600 MHz. It is a great deal of delay but each data line has an accumulative delay and it goes up to 4.5 ns.
I have found a good approach implementing the second pair of IODELAYs coming from user logic and not in a cascaded way directly from an IOB, using the DATAIN input instead of IDATAIN. In this way, I have flexibility to place the IODELAYs as close as possible.
drjohnsmith
Basically , DONT
Analyse why you need such a long delay,
consider registering in the signal,
cesarcf
I do need it because the input signals are a data bus with a progressive skew among each line, so I have no option.
Furthermore, a fine adjustment is needed thus if I register the signals the delay will be too higher.
drjohnsmith
4.5 ns is one heck of a delay between signals on a bus,
Whats the data rate on the bus ?
   this is for receive, transmit or both at the FPGA ?
cesarcf
drjohnsmith
Thats doubly amazing. 600 MHz is 1.67 ns per cycle,
thats over two clocks worth of delay....
Wow..
