a.gamez
BRAM not meeting timing
How one would go about getting this AXI BRAM module to meet timing? It seems that the biggest delay is inside AXI protocol routing that belongs to the IP core, so I can really touch inside that. It should run at 5ns = 200MHz, which is well below the maximum rate of BRAM, as I understand it.
Thanks!
Paths for end point u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/u_axi4_read/m_axi_rdata[31]_dff_25_14 (SLICE_X103Y62.A6), 85 paths
 Slack (setup path):     -0.709ns (requirement - (data path - clock path skew + uncertainty))
   Source:               u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/ramloop[138].ram.r/v6_noinit.ram/NO_BMM_INFO.SDP.SIMPLE_PRIM36.ram (RAM)
   Destination:          u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/u_axi4_read/m_axi_rdata[31]_dff_25_14 (FF)
   Requirement:          5.000ns
   Data Path Delay:      5.297ns (Levels of Logic = 3)
   Clock Path Skew:      -0.377ns (0.998 - 1.375)
   Source Clock:         s_processing_clk_c rising at 0.000ns
   Destination Clock:    s_processing_clk_c rising at 5.000ns
   Clock Uncertainty:    0.035ns
   Clock Uncertainty:          0.035ns  ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE
     Total System Jitter (TSJ):  0.070ns
     Total Input Jitter (TIJ):   0.000ns
     Discrete Jitter (DJ):       0.000ns
     Phase Error (PE):           0.000ns
   Maximum Data Path at Slow Process Corner: u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/ramloop[138].ram.r/v6_noinit.ram/NO_BMM_INFO.SDP.SIMPLE_PRIM36.ram to u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/u_axi4_read/m_axi_rdata[31]_dff_25_14
     Location             Delay type         Delay(ns)  Physical Resource
                                                        Logical Resource(s)
     RAMB36_X0Y3.DOBDO6   Trcko_DOB             1.800   u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/ramloop[138].ram.r/v6_noinit.ram/NO_BMM_INFO.SDP.SIMPLE_PRIM36.ram
     SLICE_X17Y25.C4      net (fanout=1)        0.895   u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/ramloop[138].ram.ram_doutb<6>
     SLICE_X17Y25.C       Tilo                  0.043   u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/has_mux_b.B/Mmux_dout_mux_1269
     SLICE_X103Y32.C5     net (fanout=1)        1.496   u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/has_mux_b.B/Mmux_dout_mux_1269
     SLICE_X103Y32.CMUX   Tilo                  0.244   u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/has_mux_b.B/Mmux_dout_mux_1023
                                                        u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/has_mux_b.B/Mmux_dout_mux_623
                                                        u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/has_mux_b.B/Mmux_dout_mux_5_f7_22
     SLICE_X103Y62.A6     net (fanout=1)        0.810   u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/has_mux_b.B/Mmux_dout_mux_5_f723
     SLICE_X103Y62.CLK    Tas                   0.009   u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/u_axi4_read/m_axi_rdata[31]_dff_25<14>
                                                        u_art_cap_rx_chains/u_chain/gen_mtd.u_art_mtd/u_axi4_reorder/gen_BRAM_L15.u_blk_mem_0/U0/xst_blk_mem_generator/gaxibmg.axi_blk_mem_gen/valid.cstr/has_mux_b.B/sel_pipe<6>23
     Total                                      5.297ns (2.096ns logic, 3.201ns route)
                                                        (39.6% logic, 60.4% route)
adem369
I did not undestand where is the problem in your design, because the details you gave is not enough, I belive. But, since this is the intra-clock path problem, the solution (most of the time) is adding pipeline register. Xilinx IP cores have this option where required.
