mildred
I am having several timing problems i was wondering if it was useful to cascade several bufg?
I have a 200 MHZ clock that comes out from a bufg and is directed to several different modules, is it useful to put another bufg in front of every module?
dsheils
Hi @mildred
Cascaded clock buffers are rarely a good idea. They will increase your clock insertion delay and may increase clock skew.
We would need more details on the problem you are seeing. Can you attach the timing summary report for the failing paths? Also report_methodology also.
ghasemi_r
No, it never help you
If you have multi domain clock, you need to use FIFO
in some cases, use :"set false path" .
some times the design need more time or it is complex, so it is better to register (pipe) some of REGs.
dsheils
Hi @mildred
dpaul24
@mildred ,
No.
You need to analyze the failing failing paths. As mentioned in the above post, double click on the failing paths the tool reports and analyze the or use the TCL commands.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
