Delays reported by Vivado
Given a net NetAB linking an output of LUTA to an input of LUTB. When increasing the fanout, i.e the output of LUTA is also linked to an input of another LUTC, i found that the delay of NetAB has increased by the same amount in the Max slow, Min slow, Max fast and Min fast process corners. Is it normal? I was expecting that the delay increase is the highest in the Max Slow and the lowest in the Min fast process. does anyone have an explanation?
Thank you for your help,
Based on my knowledge, increasing the fanout adds wire segments and pips (pass transistor) to the net. If modeled as an RC distributed network with (LUT) driving strengths that depend on corner cases, the delay increase should also depend on corner cases.
Can you show us an example?
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
According to Vivado Timing analyzer, The delay of the net plotted in red color in Fig.1 is equal to:
472 ps in Slow Max
314 ps in Slow Min
265 ps in Fast Max
190 ps in Fast Min
When the fanout is increased as Shown in Fig.2, the delay of the same net (red) is now equal to:
479 ps in Slow Max
321 ps in Slow Min
272 ps in Fast Max
197 ps in Fast Min
So the delay increase is equal to 7 ps in all process corners. Do you have any explanation? I expected that the delay increase should be the highest in the Slow process corner and the lowest in the Fast process corner.
