shubhamc
Design works in simulation but not on hardware
Hi all,
I am working on a vivado project in which I have Xilinx's IPs and also some of my HLS generated IPs and has ILA to observe the results. When I go for simulations , design produces desired result but when it comes to run on board it does not produce the same result. Here what I've observed in ILA is that before the desired data some garbage data comes on the data bus and I do not have any idea why is it happening.
Any suggestions would be very helpful.
bruce_karaffa
The first question will always be do you have the proper timing constraints for this design and does the design meet these constraints?
dgisselq
@shubhamc,
At one time I tried to catalog all the reasons why a design might work in simulation but not in hardware.  I probably missed some, but perhaps the list will give you a place to start.
Dan
viviany
What do those garbage data look like?
Can you paste a screenshot of the ILA waveform?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
shubhamc
Hi @bruce_karaffa
All timing constraints are met in the design.
shubhamc
Hi @dgisselq
Thanks you for sharing this. I will look into it for the solution.
shubhamc
Hi @viviany
Right now I do not have snapshot of ILA but I will share it with you but till then I can tell you that by garbage I meant to say undesired data.
Let's say we have 128 bit bus then in the starting for 3 or 4 buses thar undesired data appears and only after that the desired data comes on the bus of 128 bits.
Robiwan3
Do your post-synthesis simulation results match your pre-synthesis simulation results?
