hasaney
Effect of falling_edge/rising_edge on Max Frequency
Hi All,
Nowadays, I am dealing with a design that consists of a block ram and a circuit in front of block ram that includes multiplexers and a state machine to control the multiplexers. There are many sources to BRAM and muxes selects each source depending on the state of the FSM. The circuit could run slower than I expected
In the state transition code when I changed the clock event as rising edge speed increases to 724 Mhz. In the falling_edge, it was 362 Mhz.
Is there any meaningful exploanation?
Thanks a lot.
This code shows the state transition of the FSM
process(CLK_BRAM)
	begin
	if rising_edge(CLK_BRAM) then -- when changed to rising_edge, speed doubles
			if (RST='1') then
				state <= READ01;
			else
				state <= next_state;
			end if;
		end if;
	end process;
 RISING_EDGE
Minimum period: 1.380ns (Maximum Frequency: 724.900MHz)
Minimum input arrival time before clock: 1.790ns
Maximum output required time after clock: 4.129ns
Maximum combinational path delay: No path found
FALLING_EDGE
Minimum period: 2.759ns (Maximum Frequency: 362.450MHz)
gszakacs
Professor
Professor
"If I use the rising edge for state transition, all inputs to the BRAM would change at the same time with BRAM sampling time of input signals. For this reason I have to use falling edge for state transitions."
That's not really true.  All outputs of a flip-flop change just after the clock edge, and sample their
inputs at the clock edge.  So in fact the BRAM would see the input changes after the sampling
point.  You should see this behavior in simulation (you did simulate your design?).
The tools make sure that all data paths on the same clock edge meet hold time at the destination.
If this were not true you could never make anything as simple as a shift register or counter without
using both clock edges.
Now from your timing report:
  Clock period: 2.759ns (frequency: 362.450MHz)
  Source Clock:      CLK_BRAM falling
  Destination Clock: CLK_BRAM rising
    Total                      1.380ns (0.704ns logic, 0.675ns route)
Note that the data path delay is only half of the clock period (within 1 ps).  This is due to the
use of both clock edges, and this is what slows down your design.  You're generally best off
using the rising edge of the clock for all logic elements in the design.  Let the tools do their
job and handle the clock distribution and prevention of setup/hold time issues.
-- Gabor
-- Gabor
gszakacs
Professor
Professor
You didn't mention which device family you're using, but in most cases the RAM should
be able to run just as fast on either edge.  Since the numbers seem to reflect approximately
2:1 performance difference, my guess is that you have other parts of the design that run on the
rising edge of the clock and the critical path is crossing from one edge to the other.  You can
look at the timing analysis section of the report where it shows the worst case path (the
one used to determine the maximum frequency) and see if it is going from one clock
edge to the other in the falling_edge case.
-- Gabor
-- Gabor
hasaney
Thanks for the reply Dear Gabor,
I am using Virtex-5.
I am doing Block RAM operations in rising edge of clock. The inputs to the block RAM can be selected by the state of the system. So if I change the state transition as rising edge, there may be some hold & setup time violations.
As an more deeper explanation  this is my vhdl code.
type Tstate is (READ01,WRITE01);
signal state : Tstate := READ01;
signal next_state : Tstate;
next_state <= 	WRITE01 when state=READ01 else
		READ01 	when state=WRITE01 else
	        READ01;
ADDRB <=  ADDR_R1 when state=READ01 else
	  ADDR_W1 when state=WRITE01 else
	  ADDR_R1;
process(CLK_BRAM)
begin
    if falling_edge(CLK_BRAM) then
	if (RST='1') then
	    state <= READ01;
	else
	end if;
    end if;
end process;
at each falling edge of the clock, state changes to next_state and at the following edge (rising edge) Block RAM makes its operations (reading or writing) depending on the state (different inputs are directed to BRAM depending on the state). For example ADDRB is BRAM address port for B port.
I have added the simmulation report to the attechment.
gszakacs
Professor
Professor
-- Gabor
-- Gabor
hasaney
Thanks Mr Gobar,
I am dealing with low level VLSI design for this reason I tried to make everything on my own (hold, setup times) and don't rely on behavioral simulation because it gives no information about metastability (http://www.programmableplanet.com/author.asp?section_id=2142&doc_id=245812). Thanks to Xilinx, it manages this.
Thanks again,
Best regards.
bassman59
Historian
Historian
That sentence shows a fundamental misunderstanding of how synchronous digital logic operates.
bassman59
Historian
Historian
@hasaney wrote:
Thanks Mr Gobar,
That's because functional/behavioral simulation is not interested in metastability. It is interested in whether the logic design is correct.
Metastability is a timing/circuit implementation issue. And with modern FPGAs, it is only interesting at the FPGA pins and when you are crossing clock domains.
Otherwise, it's something with which you need not worry.
hasaney
Thanks for additional knowledge. When we look at the behavioral simulation, metastability is unavoidable (signal changed at the same time with clock pulse and sampling). There is no FF with 0 hold and setup time.
For this reason, I have planned to use PSL (Propoerty Specification Language) against metastability cases. However I learned that (thanks to Gabor),  in FPGA CAD tools, it can be handled easily.
gszakacs
Professor
Professor
1) Metastability has nothing to do with behavioral simulation.  It happens only in real hardware.  Only timing simulation can predict whether metastability is possible (i.e. setup and hold time constraints are not met).  Behavioral simulation shows zero propatation delay from the clock to the flip-flop outputs in a waveform view, but there is a "delta" delay internal to the simulation which guarantees that other flip-flops always sample the value at their inputs from before the clock edge.  This effectively guarantees that there are no hold time issues for behavioral simulation.
2)  I agree that no flipflop has both 0 setup and hold time, but no flip-flop has 0 propagation delay either.  It would be a totally useless FPGA whose flip-flops  did not meet hold time requirements under almost any condition.
Gabor
-- Gabor
