11-09-2010 01:03 PM
I used Spartan xc3s250-4cp132 device and ISE 12.3 Webpack edition to synthesize, place & route and simulate the following design. The design is timing closed. There is no timing violations but the post-place & route simulation shows oen extra clock delay. If I inreased the clock period from 10ns to 30ns there is no extra delay. Any idea where this extra clock delay comes from?
Design:
Library ieee;
use ieee.std_logic_1164.ALL;
ENTITY BeltWarn IS
PORT(k,p,s: IN std_logic;
w: OUT std_logic );
END BeltWarn;
ARCHITECTURE Behav OF BeltWarn IS
SIGNAL w_temp: std_logic;
BEGIN
PROCESS(k,p,s)
BEGIN
IF(k = '1' AND k'EVENT) THEN
w_temp <= (p AND NOT(s));
END IF;
END PROCESS;
w <= w_temp;
END Behav;
TestBench:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY Testbench IS
END Testbench;
ARCHITECTURE TBarch OF Testbench IS
COMPONENT BeltWarn IS
w: OUT std_logic);
END COMPONENT;
SIGNAL k_s, p_s, s_s, w_s: std_logic;
BEGIN
CompToTest: BeltWarn
PORT MAP(k_s, p_s, s_s, w_s);
PROCESS
BEGIN
p_s <='0'; s_s<='0';
WAIT FOR 42 ns;
p_s <='0'; s_s<='1';
WAIT FOR 40 ns;
p_s <='1'; s_s<='0';
WAIT FOR 40 ns;
p_s <='1'; s_s<='1';
WAIT FOR 40 ns;
WAIT FOR 40 ns;
WAIT;
END PROCESS;
PROCESS
BEGIN
k_s <= '1';
WAIT FOR 5 ns;
k_s <= '0';
WAIT FOR 5 ns;
END PROCESS;
END TBarch;
UCF file:
NET "k" TNM_NET = k;
TIMESPEC "TS_k" = PERIOD "k" 10 ns HIGH 50%;
NET "p" OFFSET = IN 2 ns VALID 5 ns BEFORE "k" RISING;
NET "w" SLEW = FAST;
NET "s" OFFSET = IN 2 ns VALID 5 ns BEFORE "k" RISING;
NET "w" OFFSET = OUT 6 ns AFTER "k" REFERENCE_PIN "w" RISING;
INST "w_temp" IOB=TRUE;
11-10-2010 05:32 AM
I think you may be running into a simulation issue with global set/reset. I'm not
sure if the same thing happens in VHDL simulation, but at least for Verilog there
is an automatically generated GSR signal that holds any library model in its
initial state for the first 100 ns of simulation. So what you see here may be
related to this issue. Try delaying your initial stilmulus for 100 ns and see if
the W output follows P and S by a single clock cycle then.
Gabor
11-09-2010 03:03 PM
It looks to me like your testbench is violating the timing you specify in the constraints. The
constraint:
means that signal "p" should have at least 2 ns of setup and 3 ns of hold time
with respect to the rising edge of "k". However your main process only provides
2 ns of hold time with respect to "k". Strangely though I don't see how that would
create an extra clock delay, I would think it would more likely create one less
clock if the hold time requirement exceeded 2 ns. Can you post a waveform
from the post P&R simulation to show where you see the extra delay?
11-10-2010 04:50 AM
Thanks for your reply.
I also tried with 4ns hold time. But the result is still the same. I added my simulation results, including the internal signals at the register inputs and output. Around 100ns the DFF requires two clock cycles in order to sample right value. Below is the timing analysis results.
All constraints were met.
Data Sheet report:
All values displayed in nanoseconds (ns)
Setup/Hold to clock k
|Max Setup to|Max Hold to | | Clock |
Source | clk (edge) | clk (edge) |Internal Clock(s) | Phase |
p | 0.576(R)| 0.743(R)|k_BUFGP | 0.000|
s | 0.261(R)| 1.172(R)|k_BUFGP | 0.000|
Clock k to Pad
| clk (edge) | | Clock |
Destination | to PAD |Internal Clock(s) | Phase |
w | 5.396(R)|k_BUFGP | 0.000|
COMP "p" OFFSET = IN 2 ns VALID 5 ns BEFORE COMP "k" "RISING";
Worst Case Data Window 1.319; Ideal Clock Offset To Actual Clock 0.417;
| | | Setup | Hold |Source Offset|
Source | Setup | Hold | Slack | Slack | To Center |
p | 0.576(R)| 0.743(R)| 1.424| 2.257| -0.417|
Worst Case Summary| 0.576| 0.743| 1.424| 2.257| |
COMP "s" OFFSET = IN 2 ns VALID 5 ns BEFORE COMP "k" "RISING";
Worst Case Data Window 1.433; Ideal Clock Offset To Actual Clock 0.044;
s | 0.261(R)| 1.172(R)| 1.739| 1.828| -0.044|
Worst Case Summary| 0.261| 1.172| 1.739| 1.828| |
COMP "w" OFFSET = OUT 6 ns AFTER COMP "k" REFERENCE_PIN BEL "w" "RISING";
Bus Skew: 0.000 ns;
PAD | Delay (ns) |Edge Skew (ns)|
w | 5.396| 0.000|
Timing summary:
Timing errors: 0 Score: 0 (Setup/Max: 0, Hold: 0)
Constraints cover 3 paths, 0 nets, and 4 connections
Design statistics:
Minimum period: 3.160ns{1} (Maximum frequency: 316.456MHz)
Minimum input required time before clock: 0.576ns
Minimum output required time after clock: 5.396ns
------------------------------------Footnotes-----------------------------------
1) The minimum period statistic assumes all single cycle delays.
11-10-2010 05:32 AM
Gabor
11-10-2010 07:59 AM
You are right, When I wait 100ns, the results are as expected. Thanks for the solution. I attached the results with 100ns wait included.
