whisper
Get a gate delay in xilinx (verilog)
Hello,I am a Xilinx beginner
And I already get the gate delay in my program
But I have some question about why the delay time was not bigger than (9.157*3)ns
I have call the module "Look ahead adder "three time, but why?
program:
module Look_Ahead_Adder's delay:
moudle Look_Ahead_Multiplier's delay:
gszakacs
Instructor
Instructor
The total delay being reported is from pad to pad.  If you look at the details, a large portion of this (about 4.5 ns) is actually delay through the input and output buffers.  Adding another module in series does not add more input or output buffers, so the additional delay will be smaller.  Also note that routing delays can be larger than logic delays, especially if your input and output pins are not located near eachother.
And by the way it's not a "program" but a hardware description.
-- Gabor
gszakacs
Instructor
Instructor
-- Gabor
whisper
Appreciate your answer
pulim
Hi Whisper,
If the gabor's post answered your question please close the thread by marking the post as accepted solution.
This is good forum practice and it will help the other forum users also.
Manusha.
whisper
Thank you for your suggestion
