ssampath
Voyager
Voyager
How tool will do the timing analysis if we dont mention the input/out delays ?
HI Friends,
In my design i dont have any input/output delay constraints. How tool will do the timing analysis in this case ?
If i put delay as 0, will it cause any functional issue ?
Any help or suggestion is highly appreciated.
-Sam
-Sampath
hongh
If you don't create any input/out delays in the design, tool will not analyze the input/output paths.
(If you report_timing on the path, the requirement should be infinite)
We suggest you set the input/output with the board information. If you set an value(Ex: 0) for the paths, it may cause the timing violation and more run time will be used.
hongh
