Observer ssneed
Input DDR timing constraint with clock wizard
Hello.  I have a DDR input I am capturing with an IDDR primitive.  The DDR clock is routed through an IBUFG and then to an instance of a Clock Wizard.  The following constraints are applied, but the timing report lists the setup slack as -5.5 ns.  I plan on using the dynamic phase adjustment feature of the Clock Wizard module to meet my timing constraints, but I would like to set up the constraints and phase setting of the Clock Wizard so that I meet timing after implementation.
1) am I doing something wrong with my constraints that causes the -5.5ns slack?
2) is it possible to account for the delay of the Clock Wizard to eliminate this negative slack?
( I have manually set the Clock Wizard phase to 0 and to 90 degrees and have noticed no difference in the timing report)
-Sean
create_clock -period 5.880 -name DDRC_CLOCK -waveform {0.000 2.940} [get_ports fmc_ha_00_p]set ddr_clock_period 5.880
set dv_before_ddr_pos_edge 0.730
set dv_after_ddr_pos_edge 0.730
set dv_before_ddr_neg_edge 0.730
set dv_after_ddr_neg_edge 0.730
# CHA
set_input_delay -clock DDRC_CLOCK -max [expr $ddr_clock_period/2 - $dv_before_ddr_pos_edge] [get_ports fmc_ha_04_p]
set_input_delay -clock DDRC_CLOCK -min [expr $ddr_clock_period/2 - $dv_after_ddr_pos_edge] [get_ports fmc_ha_04_p]
set_input_delay -clock DDRC_CLOCK -clock_fall -max -add_delay [expr $ddr_clock_period/2 - $dv_before_ddr_neg_edge] [get_ports fmc_ha_04_p]
set_input_delay -clock DDRC_CLOCK -clock_fall -min -add_delay [expr $ddr_clock_period/2 - $dv_after_ddr_neg_edge] [get_ports fmc_ha_04_p]
Re: Input DDR timing constraint with clock wizard
It looks to me that the expressions you used to calculate the input delay values are not correct.
Which XDC template are you referring to?
Can you show us the timing diagram of the interface?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
-vivian
Observer ssneed
Hi Vivian,
I am attaching a picture of my input clocking network.  The DDR clock rising and falling edges are aligned mid-bit with the data.
I didn't use a template provided in Vivado.  I used one out of a Xilinx instructor led training manual.  I will try to locate a Vivado template and figure out what I am doing wrong.
-Sean
Observer ssneed
I compared my constraints to the Center Aligned Double Data Rate XDC template and found my error.  The constraints I was using from the training manual I have were correct with respect to the template, I just copied them wrong.
Thanks for your help Vivian.
-Sean
