Large clock Skew
Hi there,
I have a problem with large clock skew. My clock comes from a MMCE is distributed. The fanout from the this output buffer is fo= 2500 which results in large arrival clock delay and lots of hold timing violations. By the synth_design with the hierarchy rebuilt I can work round the issue however I would rather not do this.
I can't obtain timing closure otherwise.
James.
Guide
Guide
I am having trouble following some details in your post...
Is the clock from an "MMCM", and if so, what kind of buffer do you use on the output of the MMCM (it pretty much needs to be a BUFG or a BUFH). Is there more than one clock involved, or is the skew on the same clock.
A properly designed FPGA should have very little clock skew; the clock trees are all very well balanced, and have only a few hundred picoseconds of worst case skew - in general this is small enough to not create any problems for a design.
If you are having trouble, then, more likely, there is a problem with how your clock system is constructed...
You should tell use more about the problem - what device, what tool, what frequencies. Most importantly, you should give us details about your clock management, and post a timing report for the failed path. We can probably tell you more with this information.
Avrum
HI @jcarriga
Yes in addition to explaing what exactly is the BUffer used post MMCM (BUFG as we assume?),
could you also please elaborate on  how hierarchy rebuilt option  is helping  on reducing the fanout of the clock buffer  and there reduce the clock insertion delay?
please Share timing  reports if possible.
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
