No clock when program the PL of ZCU104
I am using ZCU104 board for a pure logic development. I do can download the image into the PL by jtag, but it seems the clock not function correctly.
Could any one help? Thanks a lot!
The test code and constrain as following.
module div_clk(rst, clkp, clkn, div_clk, pbutton, LED);
parameter DIVCNT = 2**20;
input rst;
input clkp;
input clkn;
output div_clk;
input pbutton;
output LED;
wire clk;
reg div_clk;
reg [23:0] cnt;
IBUFDS ins_clkbuf(
    .I(clkp),
    .IB(clkn),
    .O(clk));
always @(posedge clk or posedge rst)
  if (rst)
    begin
    cnt <= 0;
    div_clk <= 0;
    end
  else if(cnt == DIVCNT)
    begin
    cnt <= 0;
    div_clk <= ~div_clk;
    end
  else
    cnt <= cnt + 1;
assign LED = pbutton;
endmodule
create_clock -period 10.000 -name clk -waveform {0.000 5.000} [get_ports clkp]
set_property PACKAGE_PIN H11 [get_ports clkp]
set_property IOSTANDARD LVDS [get_ports clkp]
set_property PACKAGE_PIN G11 [get_ports clkn]
set_property IOSTANDARD LVDS [get_ports clkn]
set_property PACKAGE_PIN C3 [get_ports rst]
set_property IOSTANDARD LVCMOS33 [get_ports rst]
set_property PULLDOWN true [get_ports rst]
set_property PACKAGE_PIN B5 [get_ports div_clk]
set_property IOSTANDARD LVCMOS33 [get_ports div_clk]
set_property PACKAGE_PIN A5 [get_ports LED]
set_property IOSTANDARD LVCMOS33 [get_ports LED]
set_property PACKAGE_PIN B3 [get_ports pbutton]
set_property IOSTANDARD LVCMOS33 [get_ports pbutton]
Hi @shenglin ,
Yes to correct pin location of 300 MHz clock, we already have CR in place.
Ashish
The cause found is error in "ZCU104 Evaluation Board User Guide", see following mismatch between the user guide and schematic
Hi @shenglin ,
Yes this is bug with user guide and I have reported it through CR.
Correct pins are -
CLK_125_P - F23
CLK_125_N - E23
Ashish
CLK_300_P
CLK_300_N
signals connection is also wrong.
Hi @shenglin ,
Ashish
