fpgalearner
Voyager
Voyager
OSERDES timing issue
I am using oserdes in DDR mode at 400 MHz which takes 8 inputs at 100 MHz parallelaly.
 generate if (FPGA_TYPE == 8) begin: G_TX_KINTEXUS
      for (i=0; i <= 1; i = i + 1) begin: G_OSERDES
         OSERDESE3 #(
                     .DATA_WIDTH(8),              // Parallel Data Width (4-8)
                     .INIT(1'b0),                 // Initialization value of the OSERDES flip-flops
                     .IS_CLKDIV_INVERTED(1'b0),   // Optional inversion for CLKDIV
                     .IS_CLK_INVERTED(1'b0),      // Optional inversion for CLK
                     .IS_RST_INVERTED(1'b0),      // Optional inversion for RST
                     .SIM_DEVICE("ULTRASCALE"))   // Set the device version (ULTRASCALE, ULTRASCALE_PLUS,
                                                  // ULTRASCALE_PLUS_ES1, ULTRASCALE_PLUS_ES2)
         I_OSERDESE3(
                     .OQ(txdata_ser[i]),          // 1-bit output: Serial Output Data
                     .T_OUT(txoe_ser[i]),         // 1-bit output: 3-state control output to IOB
                     .CLK(txclk),                 // 1-bit input: High-speed clock
                     .CLKDIV(txosclkdiv4),          // 1-bit input: Divided Clock
                     .D(txdata_reg_shift[i*8+:8]),      // 8-bit input: Parallel Data Input
                     .RST(reset),                 // 1-bit input: Asynchronous Reset
                     .T(tx_noe));                 // 1-bit input: Tristate input from fabric
      end
I used MMCM for vu440 and generated both clocks. It complaining about 2 failing paths which is going to its tristate input T coming out from T_OUT and finally going to output port via OBUFT.
Path 291-3.262332module_ds/tx_oe/Cdata_out_fpga1[1]3.2631.6481.6150.00FB1_uA|I_module_ds.clk_100_pll_derived_clock_CLKIN1 MaxDelay Path 0.000ns -datapath_only
Path 292-3.032332module_ds/tx_oe/Cdata_out_fpga1[0]3.0321.6861.3460.00FB1_uA|I_module_ds.clk_100_pll_derived_clock_CLKIN1 MaxDelay Path 0.000ns -datapath_only
Max SkewFastOSERDESE3/CLKOSERDESE3/CLKDIV0.3200.417-0.097BITSLICE_RX_TX_X1Y394I_module_ds/I_module_ds_tx/G_TX_KINTEXUS.G_OSERDES[0].I_OSERDESE3/CLK
Max SkewFastOSERDESE3/CLKOSERDESE3/CLKDIV0.3200.411-0.092BITSLICE_RX_TX_X1Y405I_module_ds_ds/I_module_ds_tx/G_TX_KINTEXUS.G_OSERDES[1].I_OSERDESE3/CLK
and using this constraints didn't help:
set_false_path -from [get_pins I_module_ds/tx_oe/Q]
Any suggestion?
avrumw
Expert
Expert
This is a different (and known) issue.
Take a look at this post on managing the clock skew to the OSERDES in UltraScale.
Avrum
viviany
Not sure what paths they are.
Information not enough.
Would you post your complete timing report?
And can you show us the schematic of the related timing paths?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
fpgalearner
Voyager
Voyager
Summary
Name Path 291
Slack -3.263ns
Source I_module_ds/tx_oe/C   (rising edge-triggered cell FDCE clocked by FB1_uA|I_module_ds.clk_100_pll_derived_clock_CLKIN1  {rise@0.000ns fall@5.000ns period=10.000ns})
Destination data_out_fpga1[1]
Path Group **default**
Path Type Max at Slow Process Corner
Requirement 0.000ns (MaxDelay Path 0.000ns)
Data Path Delay 3.263ns (logic 1.648ns (50.499%)  route 1.615ns (49.501%))
Logic Levels 3  (LUT1=1 OBUFT=1 OSERDESE3=1)
Output Delay 0.000ns
Timing Exception MaxDelay Path 0.000ns -datapath_only
Data Path
Delay Type Incr (ns) Path (ns) Location Netlist Resource(s) Partition
 (r) 0.000 0.000 Site: SLICE_X297Y455 I_module_ds/tx_oe/C
FDCE (Prop_AFF_SLICEL_C_Q) (r) 0.140 0.140 Site: SLICE_X297Y455 I_module_ds/tx_oe/Q
net (fo=2, routed) 0.082 0.222  I_module_ds/tx_oe
   Site: SLICE_X297Y455 I_module_ds/tx_oe_RNI9U1D.O/I0
LUT1 (Prop_B6LUT_SLICEL_I0_O) (f) 0.053 0.275 Site: SLICE_X297Y455 I_module_ds/tx_oe_RNI9U1D.O/O
net (fo=2, routed) 0.767 1.042  I_module_ds/I_module_ds_tx/tx_oe_i_0
   Site: BITSLICE_RX_TX_X1Y405 I_modulen_ds/I_module_ds_tx/G_TX_KINTEXUS.G_OSERDES[1].I_OSERDESE3/T
OSERDESE3 (Prop_OSERDES_BITSLICE_COMPONENT_RX_TX_T_T_OUT) (f) 0.450 1.492 Site: BITSLICE_RX_TX_X1Y405 I_module_ds/I_module_ds_tx/G_TX_KINTEXUS.G_OSERDES[1].I_OSERDESE3/T_OUT
net (fo=1, routed) 0.766 2.258  I_module_ds/I_module_ds_tx/txoe_ser[1]
   Site: AV31 I_module_ds/I_module_ds_tx/G_txdata[1].G_obuft.I_OBUFT_txdata/T
OBUFT (TriStatE_OUTBUF_HPIOB_T_O) (r) 1.005 3.263 Site: AV31 I_module_ds/I_module_ds_tx/G_txdata[1].G_obuft.I_OBUFT_txdata/O
net (fo=0) 0.000 3.263  data_out_fpga1[1]
   Site: AV31 data_out_fpga1[1]
Arrival Time  3.263
Destination Clock Path
max delay 0.000 0.000
output delay -0.000 0.000
Required Time  0.000
avrumw
Expert
Expert
The problem is with your constraints. Somewhere in the design you have a command that looks like
set_max_delay -datapath_only 0 <some path enumeration>
This includes the path that ends at the primary output of your FPGA. A set_max_delay 0 is essentially impossible to meet. It is also really unusual to have a set_max_delay -datapath_only to a primary output of the FPGA.
Unless you have "correct" constraints, the timing analysis is meaningless - and this is clearly not a correct constraint...
Avrum
fpgalearner
Voyager
Voyager
hi @avrumw
i could manage to remove
but I still have pulse width skew problem which i also mentioned above.
see attachments.
avrumw
Expert
Expert
Avrum
