Processor System Register Latch pin with no clock
I'm having trouble figuring out if its safe to ignore this message or what I should do about it.
"Register/Latch pins with no clock driven by root clock pin: tx_path_i/zynq_ultra_ps_e_0/U0/PS8_i/EMIOSPI0SCLKO (1)"
I'm using a Zync Ultrascale+ and have of the processor system SPI blocks on EMIO that I'm routing to PL pins.
Can I ignore these?
Given these pins are sourced in the processor system, I don't think I can write a constraint to fix the problem?
What would a false path constraint look like for this?
Chuck_S
