Visitor randre
Slack saturation
I synthesized some code with Vivado 2016.4. I constrained the only one clock i have, obtaining a negative slack.
(create_clock -period 8.000 -name clk -waveform {0.000 4.000} [get_ports clk])
Then i tried to lower the clock frequency to obtain a positive slack. I tried to calculate the maxinum clock frequency with fmax = 1 / (Tck – WNS ) but I still obtained a negative slack:
So i tried to lower a lot the clock frequency but the slack remains fixed to a certain negative value, indipendently to the clock frequency:
Paths with negative slack are all related to a block wich has the main clock as input. It returns a 60 seconds clock as output (used as input by a downstream counter):
This is the code of that block:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity clk_60s is
	generic( f_ck_in  : positive := 125000000;  --input freq. in hertz
	         t_ck_out : positive := 60  --output clock period in seconds
	port(
	 clk125Mhz : in  std_logic;
	 clk60s    : out std_logic := '0'
end clk_60s;
architecture arc of clk_60s is
signal count : integer := 0;	 --counter signal
signal out_state: std_logic := '0';
begin
	increase: process(clk125Mhz)	 begin
	if (clk125Mhz = '1') then cont <= count + 1;
	   if (count = f_ck_in * t_ck_out/2) then out_state <= not out_state; clk60s <= out_state; end if; --i divide by 2 to have a  50% duty cycle
    end if;
	end process increase;
end arc;
What do you think I have to check to solve this issue? Thank you.
Re: Slack saturation
I think what you have there would not synthesis into synchronous logic and would therefore give you timing problems,
I think you might have more luck with the the following;
begin
  if rising_edge(clk125Mhz) then
    cont <= count + 1;
  end if;
The key part is the rising_edge(clk125Mhz). This should then synthesis synchronous logic and hopefully meet timing
Simon
begin
    cont <= count + 1;
  end if;
Simon
Visitor randre
Hi Simon. Thanks for your answer.
Your suggestions solved my problem.
What do you mean when you say " what you have there would not synthesis into synchronous logic and would therefore give you timing problems"?
Has this kind of problem a name so i can search it in literature?
I really thank you for your time.
Andrea.
As I understand it the synthesis engine looks at the way code is written and infers the required hardware from that.
If you synthesise both processes and then look at the schematic that is created (elaborated design schematic may give you more of a clue as to what is going on at the gate level) then you will get some idea of what the tool was trying to do with your code.
In general (for VHDL at least) you need a if rising_edge(clk) type statement to infer a flip flop (synchronous design). The code you posted will generate an asynchronous sea of gates that attempts to count as fast as possible when clk125MHz was high.
Check out Chapter 4 (HDL Coding Techniques (at least it's chapter 4 in the document version I'm looking at anyway) in UG901 Synthesis User Guide for more detailed information
Simon
