Visitor 1315chw
[Timing 38-282] The design failed to meet the timing requirements. Please see the timing summary report for details on the timing violations.
Voyager
Voyager
Re: [Timing 38-282] The design failed to meet the timing requirements. Please see the timing summary report for details on the timing violations.
This is an inter-clock timing violation. Are you sure it's a valid path that needs to be timed? Generally, data exchanged between clock domains pass through a mechanism (e.g., a FIFO) that allows data to be transferred safely, regardless of the timing relationship between the clocks. In such a case, that inter-clock timing path needs to be marked as a False Path, so the tool doesn't waste time trying to meet timing.
-Joe G.
Teacher xilinxacct
@1315chw
Can you reduce the clock speed and get it to operated successfully?
Voyager
Voyager
-Joe G.
Visitor 1315chw
Yes,I copied the xdc templetes of the ip core to my xdc file,and it works!But I have a new problem with generating bitstream.It's[DRC23-20]
Visitor 1315chw
I just copied the templetes to my xdc file,and it works!Thank you for your reply.
Regards,William
