Anonymous
Not applicable
Timing after P&R is bad then synthesis ?
After synthesis my project's biggest setup slack is -0.03 ns, and there is less than 20 path cannot match the timing. So I believe the P&R tool will help to fix this violation.
But after P&R, the timing is absolute wrong! The worst path has a -0.5 ns setup slack. And the number of path can't match the timing is more than 500.
My question is is this normal? Or am I make some mistake?
driesd
Hi Askformyhand1,
As you can find in the Ultrafast Methodology Guide (see link Deepika), it is perfectly normal that you can (almost) meet timing after synthesis, but have problems after placement or after routing.
According to the methodology guide, we recommend to verify timing and solve problem after each stage (synthesis, placement, (physopt), routing) as they each have their own type of problems.
Typical causes for large timing violations after synthesis are:
–Invalid constraint → Fix constraint
–Requirements too restrictive → Check clock interaction
–Many levels of logic → Improve RTL (ex: pipeline)
–Missing synthesis attributes → Modify synthesis settings
Typical causes for large timing violations after placement are:
–High fanout nets
–Bad floorplan and/or bad IO placement
–Over utilization
–SLR crossings on SSI devices
Physopt is not enabled by default but can resolve some of these issue like high-fanout.
Typical causes for large timing violations after physopt are:
–PhysOpt only works on top 100 offenders -> rerun physopt with various options
–High fanout nets driven from LUTs
–DONT_TOUCH properties that prevent optimizations
Typical causes for large timing violations after routing are:
–Hold fixing → to identify, run route_design with:
• set_false_path –hold –from [all_registers]
• Report timing actual vs estimated
–Congestion
Tips to resolving timing issues after route:
– Overconstrain during placement using set_clock_uncertainty to 500ps and set it back to 0 after physopt.
– Incremental placement
– OOC place and route of sub blocks
Try to get WNS below 300ps after each stage. (this is a guideline, no hard rule) ... of course you need to meet timing after routing! ;)
There are definitely designs that have much larger WNS after synthesis, but this will have an effect on runtime and you are not guaranteed to easily meet timing after routing. The earlier you can resolve problems, to more the tools can concentrate on the typical problems of that stage.
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
hongh
After synthesis, the route delay used is estimated value, not actually value.
So it's an expected behavior for timing tool.
You can try the other stratedies in implementation.
vemulad
To add, you may go through this UG http://www.xilinx.com/support/documentation/sw_manuals/ug949-vivado-design-methodology.pdf
From Page-212, it talks about Timing closure techniques.
Deepika.
Deepika.
Anonymous
Not applicable
Hi, V
Thanks for your reply. That's acture what I want to know.
But I'm confused about the following situation.
1. Run Synthesis.  Only 5 paths cannot reach the timing, and each slack is less than 0.03 ns.
2. I think the timing after synthesis is good enough. So stop optimize the HDL and Constrain.
3. Run P&R. Got really bad timing. More than 100 path cannot reach the timing.
4. The bad path of Syn and P&R is different.
Question: Which path should I optimize first ?
driesd
Hi Askformyhand1,
–High fanout nets
–Over utilization
–Congestion
Best regards
Dries
