sasindugeemal
Total hold slack fails while worst hold slack passing
I setup the Example design of DDR4 IP for  XCKU060-1FFVA1517C device. After synthesis it shows THS is failed. But the WHS is a positive value. Can you explain the reason behind it?
Sasindu
@sasindugeemal
In your screenshot, WHS is a negative number, -0.737.  This indicates your design is failing hold timing - but the color (blue) of the number is wrong and should be red.
Please tell us the version of Vivado you are using.
Hopefully someone from Xilinx will file a request to get this fixed.
Mark
sasindugeemal
I am using Vivado 2019.2. Also, it seems like DDR4 example synthesized design timing is failing on Vivado 2019.2. Can you verify that too?
Sasindu
avrumw
Expert
Expert
Can you post the detailed timing report of the worst failing hold check?
Avrum
sasindugeemal
I have attached all the screenshots and .rpx file below
