cleber
Virtex 6 hold time violations
I have a problem with hold time violations. It is a middle sized design for a xc6vlx240t-2 and uses about 40% of the FPGA.
When i build the design for speedgrade 3 everything is fine, but for speedgrade 2 i get the hold violations because the clock skew is bigger than the data delay and somehow the router fails to solve this.
Tool version: ISE 12.4
Example:
 Hold Paths: Default period analysis for net "d_clk"
 Paths for end point i2c_wrapper_I/si570_configurator_I/Mram_MEM1 (RAMB36_X3Y43.ADDRARDADDRL7), 1 path
 Slack (hold path):      -0.012ns (requirement - (clock path skew + uncertainty - data path))
   Source:               i2c_wrapper_I/si570_configurator_I/mem_read_addr_2 (FF)
   Destination:          i2c_wrapper_I/si570_configurator_I/Mram_MEM1 (RAM)
   Requirement:          0.000ns
   Data Path Delay:      0.125ns (Levels of Logic = 0)
   Clock Path Skew:      0.137ns (0.591 - 0.454)
   Source Clock:         d_clk rising
   Destination Clock:    d_clk rising
   Clock Uncertainty:    0.000ns
   Minimum Data Path at Fast Process Corner: i2c_wrapper_I/si570_configurator_I/mem_read_addr_2 to i2c_wrapper_I/si570_configurator_I/Mram_MEM1
     Location                   Delay type         Delay(ns)  Physical Resource
                                                              Logical Resource(s)
     SLICE_X52Y218.CQ           Tcko                  0.115   i2c_wrapper_I/si570_configurator_I/mem_read_addr<3>
     RAMB36_X3Y43.ADDRARDADDRL7 net (fanout=7)        0.203   i2c_wrapper_I/si570_configurator_I/mem_read_addr<2>
     RAMB36_X3Y43.CLKARDCLKL    Trckc_ADDRA (-Th)     0.193   i2c_wrapper_I/si570_configurator_I/Mram_MEM1
     Total                                            0.125ns (-0.078ns logic, 0.203ns route)
                                                              (-62.4% logic, 162.4% route)
The very same code is used in another design that fills up the FPGA(speedgrade 2) to 90%, this design has it's problem to meet the setup time, but no problem with hold times.
The constrain for the clock is:
NET "i2c_wrapper_I/clk_20" TNM = "CLK20";
TIMESPEC TS_CLK20 = PERIOD "CLK20" 20 MHz HIGH 50 %;
And according to the clock report it is using the BUFGCTRL_X0Y29.
In theory i could of course set manual constrains to increase the data delay or insert some logic (though that would not work in the xaui code from xilinx), but i'm sure that there would be always another path with a hold violation.
I also tried things like making the PBLOCKs of the modules very small or big, but that not really change the situation.
So does somebody know the magic switch/constrain to get the router to fix hold time violations?
(export RT_FORCE_HOLD_ROUTER=1 does not help)
Christian Leber
                                                              Logical Resource(s)
paullee3
That seema to be a hold violation on Unconstrained paths, please take a look at AR31881, http://www.xilinx.com/support/answers/31881.htm, to get them constrained, please apply FROM:TO TIG or FROM:TO DATAPATHONLY on the path
cleber
No, unfortunatelly it is no a unconstrained path, today i wondered about the different naming of my constraint and the clock name in the timing report (they are actually one clock net), so i also set a constrain for d_clk, just to be sure, this changed nothing, of course.
I also let the trce run with the -u parameter so that it searches for unconstraint paths, but there were none of them in the report.
AR #31881 is also not helpfull, because in this path there is no clock domain crossing, when i set a TIG the warning will go away, but the hold violation will still exist. (most likely it will never cause a problem, but i want to be sure)
rcingham
A suggestion from the "Clutching at Straws" department:
In the Mapper Process Properties, change the Starting Placer Cost Table property value to something other than 1.
Doing that has sorted minor Timing Failures on more than 1 design here!
"If it don't work in simulation, it won't work on the board."
cleber
Thanks for the suggestion, I had different builds running,  the result of cost table 7 and extra cost table 2 (randomly choosen) was again edatastic:
FATAL_ERROR:Map:Port_Main.h:159:1.27.394.1 - This application has discovered an exceptional condition from which it
   cannot recover.  Process will terminate. For technical support on this issue, please open a WebCase with this project
   attached at http://www.xilinx.com/support.
I also had complete map runs with other parameters, but unfortunatelly the cost table parameters did not help against the hold violations.
Sunday i also let the "smartexplorer" run and the hold time violations were stable (not always exactly the same path, but very simular, e.g. different adddress bits connected to a ramblock were affected).
Anonymous
Not applicable
I suggest you may run enough SmartXplorer strategies and run enough cost tables (0~15). Have a try.
cleber
Of course i tried this.
By code changes and timing optimizations in other parts, mainly due to better placement, the hold time violations were reduced, ATM i'm only seeing them in the async fifos generated with the xilinx fifo generator, this is the worst one:
 Hold Paths: TS_ht_16_cave_htax_top_I_ht_link_I_ht_link_wrapper_I_clk200_1 = PERIOD TIMEGRP         "ht_16_cave_htax_top_I_ht_link_I_ht_link_wrapper_I_clk200_1"         TS_HTX_REFCLK * 1.5 HIGH 50%;
 Paths for end point ht_16_cave_htax_top_I/ht_link_I/ht_queue_wrapper_I/np_cntl_fifo_in_I/ht_queue_fifo_96x5/BU2/U0/grf.rf/gcx.clkx/rd_pntr_gc_asreg_1 (SLICE_X35Y4.BX), 1 path
 Slack (hold path):      -1.502ns (requirement - (clock path skew + uncertainty - data path))
   Source:               ht_16_cave_htax_top_I/ht_link_I/ht_queue_wrapper_I/np_cntl_fifo_in_I/ht_queue_fifo_96x5/BU2/U0/grf.rf/gcx.clkx/rd_pntr_gc_1 (FF)
   Destination:          ht_16_cave_htax_top_I/ht_link_I/ht_queue_wrapper_I/np_cntl_fifo_in_I/ht_queue_fifo_96x5/BU2/U0/grf.rf/gcx.clkx/rd_pntr_gc_asreg_1 (FF)
   Requirement:          1.666ns
   Data Path Delay:      0.283ns (Levels of Logic = 0)
   Positive Clock Path Skew: 3.305ns (4.864 - 1.559)
   Source Clock:         ht_refclk rising at 5.000ns
   Destination Clock:    ht_16_cave_htax_top_I/ht_link_I/ref_clk rising at 6.666ns
   Clock Uncertainty:    0.146ns
   Clock Uncertainty:          0.146ns  ((TSJ^2 + DJ^2)^1/2) / 2 + PE
     Total System Jitter (TSJ):  0.070ns
     Discrete Jitter (DJ):       0.105ns
     Phase Error (PE):           0.082ns
   Minimum Data Path at Slow Process Corner: ht_16_cave_htax_top_I/ht_link_I/ht_queue_wrapper_I/np_cntl_fifo_in_I/ht_queue_fifo_96x5/BU2/U0/grf.rf/gcx.clkx/rd_pntr_gc_1 to ht_16_cave_htax_top_I/ht_link_I/ht_queue_wrapper_I/np_cntl_fifo_in_I/ht_queue_fifo_96x5/BU2/U0/grf.rf/gcx.clkx/rd_pntr_gc_asreg_1
                                                        Logical Resource(s)
     SLICE_X37Y4.BQ       Tcko                  0.228   ht_16_cave_htax_top_I/ht_link_I/ht_queue_wrapper_I/np_cntl_fifo_in_I/ht_queue_fifo_96x5/BU2/U0/grf.rf/gcx.clkx/rd_pntr_gc<3>
     SLICE_X35Y4.BX       net (fanout=1)        0.176   ht_16_cave_htax_top_I/ht_link_I/ht_queue_wrapper_I/np_cntl_fifo_in_I/ht_queue_fifo_96x5/BU2/U0/grf.rf/gcx.clkx/rd_pntr_gc<1>
     SLICE_X35Y4.CLK      Tckdi       (-Th)     0.121   ht_16_cave_htax_top_I/ht_link_I/ht_queue_wrapper_I/np_cntl_fifo_in_I/ht_queue_fifo_96x5/BU2/U0/grf.rf/gcx.clkx/rd_pntr_gc_asreg<3>
     Total                                      0.283ns (0.107ns logic, 0.176ns route)
                                                        (37.8% logic, 62.2% route)
Is it necessary to constrain this paths too?
In another design with exactly the same source for the hypertransport core hold time violations are a complete non issue and i get them every time, no matter in how many runs i let "smart"explorer do.
scb_macb
cleber,  I noticed that the most recent hold time error you posted was due to logic crossing clock domains (different source and destination clocks).
I just solved hold time violations in my current design (same source & dest clocks) by using different cost table settings.  I ran 4 different implementations with cost table set from 2-5.  Hold time issues were corrected in two of the builds.  Another build couldn't even finish routing (unroutes).
Thanks for the succestion, rcingham.
