tomray
component switching limit error for ISE 14.2
When I use ISE 14.2 to analyze the Virtex 7 DDR3 memory interfaces, I encounter the following errors. Could someone tell me what is the problem and how to solve this. Component Switching Limit Checks: TS_ddr_clk_gen_inst_clkout1 = PERIOD TIMEGRP "ddr_clk_gen_inst_clkout1" TS_sys_clk / 1.66666667 HIGH 50%; Slack: -0.736ns (max period limit - period) Period: 6.000ns Max period limit: 5.264ns (189.970MHz) (Tdlycper_REFCLK) Physical resource: u_ddr3_8g_666/u_iodelay_ctrl/u_idelayctrl_MapLib_replicate0/REFCLK Logical resource: u_ddr3_8g_666/u_iodelay_ctrl/u_idelayctrl_MapLib_replicate0/REFCLK Location pin: IDELAYCTRL_X0Y4.REFCLK Clock network: u_ddr3_8g_666/clk_ref Slack: -0.736ns (max period limit - period) Period: 6.000ns Max period limit: 5.264ns (189.970MHz) (Tdlycper_REFCLK) Physical resource: u_ddr3_8g_666/u_iodelay_ctrl/u_idelayctrl_MapLib_replicate2/REFCLK Logical resource: u_ddr3_8g_666/u_iodelay_ctrl/u_idelayctrl_MapLib_replicate2/REFCLK Location pin: IDELAYCTRL_X0Y6.REFCLK Clock network: u_ddr3_8g_666/clk_ref Slack: -0.736ns (max period limit - period) Period: 6.000ns Max period limit: 5.264ns (189.970MHz) (Tdlycper_REFCLK) Physical resource: u_ddr3_8g_666/u_iodelay_ctrl/u_idelayctrl_MapLib_replicate4/REFCLK Logical resource: u_ddr3_8g_666/u_iodelay_ctrl/u_idelayctrl_MapLib_replicate4/REFCLK Location pin: IDELAYCTRL_X1Y1.REFCLK Clock network: u_ddr3_8g_666/clk_ref
driesd
Hi Tomray,
using a search in Document Navigator, here is the definition of Component Switching Limits in the UG612 - Timing Closure Userguide:
In your case, you are violating the REFCLK maximum frequency of the IDELAYCTRL which should be 200MHz.
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
tomray
It's my first time to post message. The error info above is not clear, so i post it again.
Period:
6.000ns
Max period limit:
Physical resource:
Logical resource:
Location pin:
Clock network:
Period:
6.000ns
Max period limit:
Physical resource:
Logical resource:
Location pin:
Clock network:
Period:
6.000ns
Max period limit:
Physical resource:
Logical resource:
Location pin:
Clock network:
driesd
Hi Tomray,
Best regards
Dries
avrumw
Expert
Expert
Actually, you are violating the minimum frequency for the IDELAYCTRL.
The IDELAYCTRL must be clocked by a reference clock that is either 200MHz +/- 10MHz, or (for a -2 or -3 device only) you can also use a 300MHz clock +/- 10MHz.
The device switching limit is saying your period of 6ns is too large for the maximum period of (1/(190MHz)), which comes out to 5.264ns.
Avrum
driesd
Good point Avrum!
Of course the MAXIMUM frequency :)
Dries
tomray
I have changed the reference clock to be 200MHz, and the error has gone.
Thanks a lot.
Another question: For Virtex 7-485T FPGA (-2), the reference clock for IDELAYCTRL must be 200MHz +/- 10MHz ?
Where could I find datasheet for this infomation ?
Thanks again for this.
driesd
Hi Tomray,
Typically such timing specifications are listed in the datasheet.
For Virtex-7, this is DS183:
Best regards
Dries
