fanout limit is hardly met
I have a high fanout signal in one of my IPs (a clock enable signal being routed to several DSP slices, the default fanout was around 5k).
I moved to a non-default but still straightforward implementation strategy (Optimized_Retiming) which sets the fanout limit to 400, it dropped the fanout of that signal to 3k.
I kept that strategy and added a new constraint:
set_property MAX_FANOUT 100 [get_nets inst/tvalid_s]
now it dropped to 1k,
why is the tool not replicating that signal a lot more and meet the fanout-limit requirement of 400?
Should I drastically reduce the MAX_FANOUT property to achieve a better performance?
is phys_opt_design -force_replication_on_net [get_nets inst/tvalid_s] the only option?
G.W.,
NIST - Time Frequency metrology
Scholar austin
Re: fanout limit is hardly met
g.w.
Fanout is not as important in a FPGA device as it would be in an ASIC.  In fact, it hardly matters at all as all paths are buffered.  Based on timing constraints the tools automatically optimize the path (replicate).  Since you do not seem to see that, it may be timing cannot be met, so it doesn't even try (gives up).  Or, your constraint is met, and it does not do any more work.
You may place the net on a BUFG to get the best timing (some newer families allow use of BUFG for any signal requiring low delay, low skew).
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi @austin,
thanks for your time
in my case that is what happened
thank you I didn't know that, I was going through all things I could improve in my design, now I just forget about fanout since the tool seems to do quite a good job replicating some signals.
how would you decide which signal should be routed through a BUFG?
G.W.,
Scholar austin
gw,
A reset, or a global enable is a good candidate to use a global or regional buffer.  If it is not used by everything, then using a BUFG is of little value,
Austin Lesea
Principal Engineer
Xilinx San Jose
