schrepta
how to constrain PLL outputs when frequency is a multiple of input and has phase delay
Hi, I'm using vivado 2013.3, I have a PLL with clkin = 100MHz, clkout0 = 40 MHz, clkout1 = 20 MHz phase delayed 270 degrees.  I have a create clock for the 100 MHz input (at the fpga port pin).  I need to use create_generated_clock for the two outputs.
For the clkout0, I have:
create_generated_clock -name clock40MHz -source [get_pins U0_adc_pll/plle2_adv_inst/CLKIN1] -multiply_by 8 -divide_by 20 [get_pins U0_adc_pll/plle2_adv_inst/CLKOUT0]. This is ok.
How do I constrain the clkout1?  create_generated_clock does not allow the -multiply_by and -edges parameters to be used together. How do I specify the different freq and phase shift? Or is there another approach or constraint type?
I've looked at the ug903-vivado-using-constraints documentation, and the user forums, did not find a solution.
muzaffer
Actually you don't have to do anything. The timer knows how the PLL is configured and propagates the clocks properly. You only need to constrain the input clock.
schrepta
How about, using the clkout0 output as the reference, and using -edges and -edge_shift as follows?
create_generated_clock -name clock20MHzp270 -source [get_pins U0_adc_pll/plle2_adv_inst/CLKOUT0]  -edges {1 3 5} -edge_shift {37.5 37.5 37.5} [get_pins U0_adc_pll/plle2_adv_inst/CLKOUT1]
comments?
muzaffer
muzaffer
not that you need it but for 20 MHz from 100 MHz your edges should be {1 6 11}; each step is 5ns so the total period is 5*(11-1) = 50 ns.
schrepta
Thank you.
