11-02-2020 02:06 PM - edited 11-23-2020 03:29 PM
Using the vivado ,we can generate the "set_multicycle_path " constraints from one bit of a register to one bit of another register via the wizard,
but how can I generate the "set_multicycle_path " constraints from one register to another register shown below in the senond figure replacing just one register bit ? The corresponding register can not be find in the dialog "Choose Start Points"
what should I write ,if I want to constrain from one register to another register replacing the register bit ?
11-06-2020 08:36 AM
You can add the register name to search all the cells with that name in your design and it will give you the command as below in the snapshot. (check Right below corner in the image)
11-06-2020 08:36 AM
