Observer dror_m
no valid object
i add a false path to an ILA core.
because the ILA is generated after synthesis then the implementation does not find it in the Design Initialization.
this cause timing issues, but when i read the false path after i open the implementation the Vivado find the path and the failing path disappear.
this is a problem because now i have timing issues in other places in the design that are not related.
Re: no valid object
Hi, @dror_m ,
You can try to run this constraint after opt_design (TCL.POST).
Could you show the set_false_path constraint you are using?
Re: no valid object
Hi, @dror_m ,
When you open the implemented design in Vivado, you see the false paths works, do you?
If do, it means the constraints you add do work in the design, and you can ignore the warning after synthesis.
This is a problem because now i have timing issues in other places in the design that are not related.
Could you explain more detial for this issue? It's better to show your timing report and schematic.
Observer dror_m
Re: no valid object
when i open the design i c that the false path didn't work. but then if i rerun the same command from the XDC the Vivado accept the constraint and the timing on this specific path is clean.
but this will not solve the issue because the Vivado tried to close timing on this path it cause failure on other paths.
Re: no valid object
Hi, @dror_m ,
Observer dror_m
Re: no valid object
this did the job:
thanks
