sobel edge detection design
I want to make a sobel edge design on Pynq Z2 without the zynq proccessor system but i have timing error.
Teacher drjohnsmith
Re: sobel edge detection design
I cant read the errors very well, way to small,
but the first one seems to be about the clock circuit, and outside its valid range,
Id suggest you sort that first, and see what happens.
When you created the Clocking Wizard, did you enter the correct input clock period, that is the real sys_clk period?  The clock wizard will not set up a MMCM or PLL with a VCO out of range providid you give it good information.
i set the board interface of clk_in1 as "sys clock", in clocking options i chose MMCM , input frequency 125MHz and output 100MHz.
auto.giannis@gmail.com  have you solved the issue? Here is the clocking wizard configuration taken from Zybo Video Workshop-Digilent.
You also need to configure "DVI to RGB Video Decoder" as explained in Page 23. I hope it will help you!
krishna@logictronix.com
Thanks for your reply, i did that but the same errors occurs.
I found the solution,
I had to remove the lines 187,188,189 and change the constraints names according to the design wrapper.
These are the correct archives.
