timing constraint warning
Hello all,
I'm recieving the following warning
[Constraints 18-619] A clock with name 'CLK_50M' already exists, overwriting the previous clock with the same name.
My XDC contains the following line:
"create_clock -period 20.000 -name CLK_50M [get_ports CLK_50M]"
My question is why? I cannot find any clock with the same name.
The main_pll.xdc contains the following line:
create_clock -period 20.0 [get_ports clk_in1]
is this the source of the problem and another related question, is there a need to define a clock constraint if one is already defined by the pll.xdc?
Jake
Re: timing constraint warning
Hi @jkunin
If the clock constraint already exists in IP non-ooc XDC then there is no need to write the constraint in top level xdc.
Deepika.
@jkunin.
Check the following Answer Record:
https://www.xilinx.com/support/answers/59799.html
--Syed
Thanks!
How bout my second question. Does a clock constraint even need to be defined if it's already defined in the pll.xdc?
Hi @jkunin
Deepika.
