Voyager
Voyager
what is the use of create_generated_clock ?
 Hi Friends,
I took a small design and i use user clock divider logic with create_generate_clock and without create_generated_clock,  i did not see any difference in the routing state and placement. in both cases vivado using BUFG after my user logic.
Then what is the use of this create_generated-clock  ?
when it will useful exactly ?
NOTE: Any help or suggestions are highly appreciated.
Thank You
S Sampath
-Sampath
Hi, @ssampath, You will see different startpoints of the clock when you use create_generated_clock or create_clock. For the internal start pin, I suggest you use create_generated_clock.
Voyager
Voyager
Hi @hongh,
Thank you,
what do you mean by stat points ? Can you pls elaborate more clearly ?
In my case experiment in both case routing happened same. anyway i will check it again.
Thank You
S Sampath
-Sampath
Hi @ssampath
answers to <this link> perhaps be useful...
Hi, @ssampath ,
Please check the 2 clock paths in your own example.
Assuming:
Clock Port -> BUFG -> MMCM -> clkou1:
To create clock for MMCM's clkou1 pin:
1. If you use create_clock on MMCM's clkou1 pin, the clock path will start from pin MMCM/clkou1
2. If you check let tool derive clock for MMCM's clkou1 pin (Create_generated_clock), the clock path will start from the "Clock Port", which is the port for its master clock.
Refer below AR
https://www.xilinx.com/support/answers/62488.html
Yash
