hotak
where are physical resource estimates in newest vivado?
and can you inform me how to use pblock to shorten slack  in newest vivado ?
rshekhaw
Hi @hotak ,
As per the PBLOCK_usbEngine_0 physical resource estimates, you need to resize the PBLOCK and exted the area covered under it to to fulfil the requirement as per the logic present inside the PBLOCK.
Raj
hotak
In ISE Pblock , to resize Pblock is to be able to improve slack time.
But I can not find that function in vivado. Were it  removed ?
Can you inform me how to improve slack to use Pblock?
viviany
Can you show us a screenshot of this function in ISE?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
