Cannot explain non-aligned PS-PL transfer issue.
Dear Users,
(Ubuntu 16.06, Vivado 17.2 64-bit, ZCU102 eval board (released silicon)).
I am seeing some strange behavior when attempting to write values from the PS-PL.
The data width of the interface HPM0_FPD is set to be 64-bit, and the transfers are all of type uint64_t to a region of memory mmap'd into user space (PS running Ubuntu 14.04).
In a sequence of non-burst write transaction (AWLEN=0) to incrementing 64-bit addresses, I am seeing WSTRB alternate between 0xFF and 0x00. 16-byte aligned transfers shown as having valid data, and other transfers being invalid.
Indeed the correct data is not read from memory and passed from PS-PL when the address ends ...XX08 (data should increment by 1 every transfer).
It is as if something in the PS thinks that the data width of the bus is 128-bit, and the non 16-byte aligned transfer is invalid.
I cannot explain this behavior without concluding that something is configured somewhere to think that the bus width is 128-bits, when in fact I have set it in the block diagram to be 64-bit. The hardware knows that only 64-bit is being transferred as AWSIZE is constantly 0x3.
Can anybody theorize how I might encounter this behavior given that I am not performing a burst transfer. Should I not always be transferring valid data under these conditions?
Many thanks,
C code to produce transfers:
for(uint64_t i = 0; i < config->datacount; i++) {
*(map + offset + i) = (config->data)[i];
Re: Cannot explain non-aligned PS-PL transfer issue.
Apologies, I could not embed the ILA waveform. Here it is...
