DRC 23-20 - IDELAYE3_cascade_crosses_byte_boundary
[DRC 23-20] Rule violation (PDCN-2708) IDELAYE3_cascade_crosses_byte_boundary - IDELAYE3 system_timer_1/u_system_timer_strobe_align/u_idelay/u_idelay_master participates in a delay cascade with IDELAYE3 system_timer_1/u_system_timer_strobe_align/u_idelay/u_idelay_slave_middle that crosses an IO Bitslice byte or bank boundary and cannot be routed properly.
I'm trying to use a cascade of 3 IDELAYE3 devices, and they're setup like in UG571 page 174 Figure 2-18 (Rev June 12, 2018), but even if I move the pin around I am getting this implementation error.
I am looking at the pin map of our device located at:
https://www.xilinx.com/support/packagefiles/usapackages/xcku115flvf1924pkg.txt
Below is the relevant cascade from the synthesis view; it looks correct to me, but maybe I'm too "close" to it.
Thanks for taking a look!
Tags (3)
Re: DRC 23-20 - IDELAYE3_cascade_crosses_byte_boundary
Hi .@.@.v.@.@.
In your implementation you have cascaded  IDELAYE3-IDELAYE3-IDELAYE3  in the chain . It should be IDELAYE3 -ODELAYE3-IDELAYE3.
other point to consider here
The delay elements can be cascaded up to the byte boundary in a downward direction, So make sure that you have at least one unused IOB below the IOB used for receiving Sync_strobe_in  input in the byte.
Reply if you have any queries, Give Kudos and Accepts as Solution
Hi .@.@.v.@.@.
You are 100% correct, thank you!
Observer chenj15
I got same error message (ODELAYE3_cascade_crosses_byte_boundary)  and I do have cascaded  IDELAYE3-IDELAYE3-IDELAYE3  in the chain.
The detailed error message is
[DRC PDCN-2709] ODELAYE3_cascade_crosses_byte_boundary: ODELAYE3 JetCam_Test/Gen_Top_RX[3].GP5301_RX_Shift_Register/ODELAYE3_inst2 participates in a delay cascade with IDELAYE3 JetCam_Test/Gen_Top_RX[3].GP5301_RX_Shift_Register/IDELAYE3_inst3 that crosses an IO Bitslice byte or bank boundary and cannot be routed properly.
Jim
Hi @chenj15
Can you please create an new thread ?  The older one is already answered and your issue seems to be little different
Observer chenj15
Thanks for replay,
How to create a new thread? I never did one before.
Jim
Hi @chenj15
Follow the below steps
