Visitor slhcxtk
prmitives
hello,
    what's the difference between component primitives and native primitives?
    Does each primitive corresponds to the real hardware logic?
   I've been confused on this for a long time. Thanks!
Community Manager
Community Manager
Re: prmitives
Native Mode = RX_BITSLICE, TX_BITSLICE. BITSLICE_CONTROL and you should use the High Speed Selectio Wizard for your design entry.
Component Mode = ISERDES, OSERDES, IDDR, ODDR, IDELAY, ODELAY, IDELAYCTRL and you use RTL as you design entry method.
The ISERDES+ IDELAY has a similiar functionality as the RX_BITSLICE, in that you capture serial data and output a parallel bus but how its implemented is different in the FPGA so the Native Mode has higher performance.
Community Manager
Community Manager
Re: prmitives
