BUFGCE_DIV inverted I input
On p31 of the Ultrascale Architecture Clocking Resources guide, v1.8 (dec'18) https://www.xilinx.com/support/documentation/user_guides/ug572-ultrascale-clocking.pdf, it states in a table that the I input pin of the buffer is not invertible.  Ie. you can't invert a clock thru it.  Yet there is a "I_IS_INVERTED" parameter defined on the Verilog library symbol for that primitive.
So can it support clock inversion or not??
Re: BUFGCE_DIV inverted I input
Hi @davemac22
table 2-8 in the UG572 seems to be incorrect here. BUFGCE_DIV supports optional inversion on I pin .
Reply if you have any queries, give kudos and accept as solution
Hi @davemac22
