BUFGMUX_CTRL selecting a clock
Hi Folks,
I am looking for a way to select bwteen two input clocks. The clocks are pixel clocks from two cameras and are recevied on an FMC board.
instanciating BUGMUX_CTRL to select between the two input clocks as :
BUFGMUX_CTRL_inst : BUFGMUX_CTRL
    port map (
    O => video_clk_bufg_mux, -- 1-bit output: Clock output
    I0 => video_clk_bufg1, -- 1-bit input: Clock input (S=0)
    I1 => video_clk_bufg2, -- 1-bit input: Clock input (S=1)
    S => cam_select -- 1-bit input: Clock select
Makes Vivado complain:
[Place 30-675] Sub-optimal placement for a global clock-capable IO pin and BUFG pair.If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING. However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule.
	< set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets IBUFG_inst_1/O] >
	IBUFG_inst_1/IBUFCTRL_INST (IBUFCTRL.O) is locked to IOB_X1Y130
	 BUFGMUX_CTRL_inst (BUFGCTRL.I0) is provisionally placed by clockplacer on BUFGCTRL_X0Y24
	The above error could possibly be related to other connected instances. Following is a list of
	all the related clock rules and their respective instances.
	Clock Rule: rule_bufgce_bufg_conflict
	Status: PASS
	Rule Description: Only one of the 2 available sites (BUFGCE or BUFGCE_DIV/BUFGCTRL) in a pair can be
	used at the same time
	 BUFGMUX_CTRL_inst (BUFGCTRL.O) is provisionally placed by clockplacer on BUFGCTRL_X0Y24
	Clock Rule: rule_gclkio_bufg
	Status: PASS
	Rule Description: An IOB driving a BUFG must use a GCIO in the same clock region as the BUFG
	 IBUFG_inst_2/IBUFCTRL_INST (IBUFCTRL.O) is locked to IOB_X1Y182
	 and BUFGMUX_CTRL_inst (BUFGCTRL.I1) is provisionally placed by clockplacer on BUFGCTRL_X0Y24
It is not clear to me how to overcome this error? my two input clocks
"video_clk_bufg1" and "video_clk_bufg2"
Are buffered with:
 IBUFG_inst_1 : IBUFG
    port map (
        O => video_clk_bufg1,
        I => fmc_in1_pclkout  -- 1-bit input: Buffer input
    IBUFG_inst_2 : IBUFG
    port map (
        O => video_clk_bufg2,
        I => fmc_in2_pclkout  -- 1-bit input: Buffer input
and the two
fmc_in1_pclkout fmc_in2_pclkout
are the IO pins.
Any help is welcome.
Scholar dpaul24
Re: BUFGMUX_CTRL selecting a clock
@ziladdev,
The answer is right inside the warning:
In your XDC set the CLOCK_DEDICATED_ROUTE to false.
See this answer record: https://www.xilinx.com/support/answers/64452.html
FPGA enthusiast!
All PMs will be ignored
Thanks for the answer. Well, the message also say it is NOT recommended to do this.
Please note that both PINS I am getting the clocks from are CC pins, so I am a bit perplexed why I am getting this message in the first place.
Scholar dpaul24
@ziladdev,
I do it everytime in big designs when I run out of clock capable pins.
That does not sound good, have you re-checked?
FPGA enthusiast!
Yes, I have now double checked and both clocks on the FMC are received on :
FMC_HPC0_LA17_CC_P
FMC_HPC0_LA00_CC_P
Positive pin of a CC pin on the FMC, both are on the same Bank 66 on the ZCU102.
Is there any primitive which I could try ? Basically this was supposed to be a quick switch between two camera inputs, I have a design for each camera and I wanted to merge both and have a swicth on the board switching camera inputs (data and pclks).
Perhaps it is relevant to add, the resulting clock, output of the BUFG_MUX is fed to the clockking wizard (MMCM) afterwards basically in order to cleanup and improve clock jitter. I will try and remove that and see if it has any effect.
I am out of ideas. I removed the two initial clock buffers and used the MUX directly on the pins and still Vivado complains. As I mentioned both clocks are on the C(lock)C(apable) pins of the ZCU102. I am even wondering if this primitive works at all or is it a bug in Vivado.
I have a similar design on a Zebboard, with exactly the same FMC card on the same pins received on CC IO and Vivado seems to do the placement and implementation without a glitch.
Any help is more than welcome.
By default, the clocking wizard introduces a buffer at its input, meaning you may be chaining two buffers together.  Check to see if there is a buffer at the input to the MMCM in addition to your BUFGMUX.  Try regenerating the clock wizard without the input buffer.
