Camera Link Receiver
Hiiiii,
      in VIVADO, for Serial IO ip, the Camera link Transmitter and Receiver Selection is Availbale upto 7 Series FPGA, and if I Select the Ultrascale Device, the Available option in the Serializer is only 4,8 bit. and No Specific interface related Selection Like 7 series Device...?
Why....????
Scholar watari
Re: Camera Link Receiver
Hi murali@1996
We have High speed SelectIO Wizard IP for the Ultrascale and Ultrascale+  devices which creates RTL that contains IO and clocking Logic such as
RX/TX Bitslice control and PLL blocks customized to the user interface requirements.
RX_TX_Bitslice, RX_bitslice and TX_Bitslice are the native primitives for US/US+ architecture and gets instantiated/configured according to the HSSIO IP settings.
In short this is totally different IP . The SelectIO wizard Utilizes IODELAY and IOSERDES  Primitives which are Component mode Primitives in US/US+ devices.
Component mode in the sense , they are created primitives from RX_TX_bitslices.
We have Application note which utilizes Component mode primitives to construct LVDS Source Synchronous 7:1 Serialization and Deserialization interfaces which  are widely used in consumer devices such as televisions and Blu-ray players for video processing when passing data between components
https://www.xilinx.com/support/documentation/application_notes/xapp1315-lvds-source-synch-serdes-clock-multiplication.pdf
Alternatively as there is no ready template for camera link receiver when using HSSIO IP, you need to analyse the interface detailing (Clocking, data rate, No of pins ) and configured HSSIO IP accordingly.
Reply if you have any queries, give kudos and accept as solution
Dear @watari
Yes,
I referred and I did the implementation also. whenever I am adding those 7:1 files to the design, the Remaining global clocks not showing in Debug search to take debug window. once the serdes macro is commented, again the expected clocks are available in debug window....
I am going to use that serdes that you have provided. in parallel i am looking for alternate solutions also.....
Thanks and regards
Murali
Scholar watari
Hi murali@1996
Could you explan your target frequency ?
It might be PLL range issue...
hi @watari
Now am in implementation stage only, not yet connected with hardware. The camera link frame clock speed is from 25 to 85MHz, i am going start with 25MHz.
regards
Murali M
