Clock tree distribution inside a FPGA.
Hello.
I'm using Vivado 2018.2 and a KCU116 board which is equipped with Kintex UltraScale+ FPGA (xcku5p-ffvb676-2-e).
After Implementation, I can see the overall floorplanning in the device tab.
In the FPGA, I found a region which has no slices as below figure 1.
figure 1.
when I enlarge the screen, actually the region has some logics as below figure 2.
figure 2.
As I enlarge once more, I can see some buffers (BUFCEs) in that region as below figure 3.
figure 3.
when I clicked the Routing Resources as below figure 4,
figure 4.
I can see lots of connections as below figure 5.
figure 5.
My question is, what is this regions?
This regions are between (SliceX?Y29 and SliceX?Y30),  (SliceX?Y89 and SliceX?Y90),  (SliceX?Y149 and SliceX?Y150) and  (SliceX?Y209 and SliceX?Y210).
I think they might be related with the clock tree (maybe they are the clock path).
Thank you for your help.
Re: Clock tree distribution inside a FPGA.
Probably you are correct.
As an aside,the graphics viewer is only loosely related to the real chip, its a graphical representation of the real chip, which is a more 3D structure,
Id understand its also deliberately obtuse so as not to give away industrial secrets.
