kinmand_ucsd
DAC output has 2.6V DC, but no sine wave
I have a single DAC design runing on a ZCU111 eval board. When I write sample data to the DACs AXIS interface, I get 2.6V on the output of the XM500 DAC0 output, but no sime wave.
Is the 2.6V DC expected? Any suggestions on what to debug for the abcense of the sine wave?
Any comments are appreciated.
drjohnsmith
If I rember, there is a demo design for that evla board , that might be a starting point,
klumsde
Yes, please try with the evaluation design.
likely the issue is that the RF PLLs on the board are not programmed by you so the tile will not have started.
nicolas05
Hello @klumsde,
Where can I find the evaluation design?
Thanks!
klumsde
try here
marianaferreiraramos
Hello @kinmand_ucsd ,
did you make any progress on that?
I have the same problem.
Mariana
