FIT rate
I'm looking for the FIT rate for the Xilinx XAZU4EV-1SFVC784Q MPSoC XU4EV 784 component.
lowearthorbit
ug116.pdf
The FIT rate is for the largest die device in a technology (16nm US+ in this case).  If you wish it more specific, you need to get a reliability briefing under NDA from Xilinx.  You request that through your distributor, or if you buy enough direct, through your direct Xilinx contact.  Depending on how new the device, ug116 may be the best it can do (there are not enough failures in testing, nor in returns).
l.e.o.
