tkleman
IDCODE XcKU060 doesn't match Ultrascale conf document
I read the IDCODE through the JTAG pins and get 0x09C8C849.  The configuration document says it should be 0xX3919093.   I don't see how I'm off by a bit or reading it backward.   Which is correct?
tkleman
Never mind, I was off by one read cycle.   I read the first output pulse as a single 1 when it was two.
tenzinc
Are you reading out the IDCODE correctly? It looks like your bits you read seems shifted but there are parts of it which look right.  However, I ask mainly because as Configuration User Guide states:
The least significant bit of the IDCODE register is always 1 (based on JTAG IEEE 1149.1). The
last three hex digits appear as 0x093 (see Table 1-5, page 20).
Your reading of "0x09C8C849" does not comply with this. Either you are reading it wrong or you have a non-Xilinx part. Most likely it's the former. What does the IDCODE read in Vivado Hardware Manager when hooked up to your board? Should match with what the guide says.
T
Get started FAST with our UltraFAST design methodoly guides and don't forget to visit our Xilinx Design Hubs for additional resources and reference.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
tkleman
