Visitor wideswath
KU060 Booting from PROM
I'm able to successfully load a .mcs into the flash memory I have connected to my KU060, and if I right click on the KU060 in Vivado Lab Edition, I can click "Boot from Configuration Memory Device" which works too.
My issue is that the FPGA doesn't boot from flash on a power cycle.  I have to load up Vivado Lab Edition each time and click "Boot from Configuration Memory Device."
How can I get my FPGA to boot from flash automatically on a power cycle?
Visitor wideswath
Re: KU060 Booting from PROM
I'm the hardware engineer.  I setup the board as directed for SPI master mode.
I got it working, but by total accident, as far as I can tell, this is totally undocumented.
When my board is connected via JTAG, the FPGA will not boot from PROM.  If I power cycle and disconnect the JTAG cable while powered down, then it boots from the flash.
Scholar austin
w,
Your board may have a selection switch for configuration.  It typically is a set of DIP switches which need to be set properly to recognize the boot source.
Lab Edition uses JTAG which is always enabled, so switch settings are not required.
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor wideswath
Thank you for the reply.  This is actually a custom board.  No switches.  So, if I can program from PROM using the option in Lab Tools, but my board doesn't come up by default... what should I be looking for?
Scholar austin
The configuration select pins need to be set to the correct values.
There are likely jumpers, or resistors that require placement, or removal.
You should ask the engineer responsible for your board.
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor wideswath
Scholar austin
w,
Sounds like it is working exactly as it should.
If JTAG is connected, it has precedence.
Austin Lesea
Principal Engineer
Xilinx San Jose
