Looking for source code for "rftool" in RFSoC Data Converter Evaluation Tool Guide
I am looking for the source code associated with the "rftool" linux user space application described in "RFSoC Data Converter Evaluation Tool UG1287 (v2018.2)" on page 45. The document references that users should be able to modify several source files on page 65,66 that seem like they would be used in the "rftool": io_interface.c/h, cmd_interface.c/h, rfdc_commands.c/h .
I have searched in the "embeddedsw" xilinx github repo and the RFDC Getting Started Guide (rdf0476-zcu111-rf-dc-eval-tool-2018-2.zip) , but I cannot find any of these files (except for the compiled binary for the "rftool" which is provided in the petalinux image in the RFDC evaluation tool guide) . Any help is appreciated. Thank you.
If you can find the BSP that comes with the reference design?
You can use petalinux to take this bsp and create a project, inside the meta_user folder you will find the source code for RFTool.
<airhorn.wav>
Thanks! That's exactly what I was looking for.
No problem, it's worth saying at this point that we will only support the RFTool 'as is' if you try modify it and use it with the GUI and it doesn't work then we can't support that.
Gotcha, that's what I expected. Cheers!
what is the difference between the rfsoc_petalinux_bsp.bsp comes with the reference design and the xilinx-zcu111-v2018.2-final.bsp.
I know this thread is quite old, but I wanted to ask if the same policy might be applied to the LabVIEW source code for the GUI?
thanks!
@ipt
The labview source code is not to be shared.
Keith
