400garrison
MPSoC Safety Manual - PS and PL Pins
We don’t quite understand the following requirement in US+ MPSoC Safety Manual.
[SMA_HFT_504] There shall be at least one unused or ground pin between all PS and used PL pins. Any unused PL pin fulfilling this requirement shall be grounded at the board level.
Can someone explain this to us?  What is the best example that we can refer to?
gnarahar
Being worked over an SR by @smarell
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
