mildred
ODELAYE3 var_load unconsitency
In one answer record the cntvaluein calculation is described by the following procedure:
  1. Start with EN_VTC = 1
  2. Program initial DELAY_VALUE to be a non-zero FIXED value, DLY0
  3. In order to switch to the new DELAY, DLY1 using the VAR_LOAD mode do the following:
    • De-assert EN_VTC. Wait 10 CLKDIV cycles.
    • Read CNTVALUEOUT of I/ODELAY
    • Load CNTVALUEIN = CNTVALUEOUT * (DLY1/DLY0)
    • Wait 10 CLKDIV cycles. Re-assert EN_VTC
https://www.xilinx.com/support/answers/60802.html
In the other one this what is described:
    1. De-assert EN_VTC. Wait 10 CLKDIV cycles.
    2. Read CNTVALUEOUT of I/ODELAY
    3. Load CNTVALUEIN = ((CNTVALUEOUT -54) * (DLY1/DLY0))+54
              For example, DLY0 = 500 and CNTVALEUOUT= 154
              The new required DLY1 = 520
              CNTVALUEIN = ((154-54)*(520/500))+54 = 158
    4. Wait 10 CLKDIV cycles. Re-assert EN_VTC
https://www.xilinx.com/support/answers/66013.html
Which is the correct one?
pthakare
Hi @mildred
The intrinsic delay is not accounted in above calculation .
In simulation the intrinsic delay is fixed  (200ps).
In order check exact intrinsic delay Set the DELAY_VALUE =0 , constraint your I/O interface ,perform the synthesis  and check the tpd (prorogation delay) of ODELAYE3 in static timing analysis .
While performing the calculation for DLY1 you need to consider this intrinsic delay .
i.e   DLY1 (considering intrinsic delay) =   DLY1 - Intrinsic delay.
pthakare
Hi @mildred
Looking at the tilte , your query is specific to ODELAYE3 and not for both (IDELAYE3 and ODELAYE3). right ?
Can you please also specify if you want to use DELAY_FORMAT= TIME or COUNT?
For ODELAYE3 , The below procedure  in https://www.xilinx.com/support/answers/60802.html  is correct
For the IDELAYE3 we need to consider clock alignment delay if DELAY_FORMAT = TIME . In this case the procedure in https://www.xilinx.com/support/answers/66013.html is correct .
mildred
Hello, thanks for your reply
I want to use ODELAYE3  in TIME mode and VAR_LOAD mode with an IDELAYCTRL.
I use this procedure:
But in simulation i find a 200 ps offset between signal datain and signal dataout compared to my desired delay DLY1. I read that it was the intrinsic delay but i thought that the procedure above enabled us to account for the intrinsic delay. Therefore i still don't understand how to achieve a desired DLY1 in ps with the DELAY_FORMAT= TIME in VAR_LOAD mode. My aim is to delay a signal by a precise and constant amount in pico seconds
pthakare
Hi @mildred
