jg_bds
OSERDES3 Implementation in (Zynq) Ultrascale+
I've been trying to implement an AXI Ethernet MAC with an RGMII interface in a Z3U.  For other reasons (ok... timing headaches) I've pushed down into the implemented design.  Below are a screenshot of the schematic of the implemented design (zoomed in to show a particular OSERDES3 instance within the Xilinx IP), and a page from the pertinent SelectIO UG.
Can anyone please reconcile these for me?
avrumw
Guide
Guide
We are running into the fact that the tools are trying to help you. This is not an OSERDESE3 instantiation...
If you look a the same document (UG571), under Figure 2.9 it says:
"Note: ODDRE1 components used in a design are translated and implemented by the Vivado design tools as OSERDESE3 components."
In other words, there isn't really such a thing as an ODDRE1 - the tools describe one, and allow you to instantiate one, but in reality they get implemented in an OSERDESE3.
This is different than an OSERDESE3 in ODDR_MODE, which is using multiple shifters in the OSERDES to implement the D and T output DDR registers (using a frankly bizarre mapping...).
So what you are looking at is actually an ODDRE1 translated into an OSERDESE3. This makes sense since the RGMII doesn't really need either deserialization (it is truly taking GMII and transmitting it DDR), and it doesn't need the tristate flip-flops. Since this is just a "vanilla" ODDR, it makes sense that it only needs CLK and not CLKDIV.
Avrum
hpoetzl
Voyager
Voyager
Hey @jg_bds
Does that OSERDES3 have ODDR_MODE set to "TRUE"?
Best,
Herbert
-------------- Yes, I do this for fun!
jg_bds
Yes; note the circle in the Cell Properties window in the upper image.
jg_bds
@hpoetzl
Thanks for the input.
Yes; note the yellow circle in the Cell Properties window in the upper image.
hpoetzl
Voyager
Voyager
Ah, sorry, I clearly missed that one ... :/
avrumw
Guide
Guide
Avrum
jg_bds
@avrumw ,
Thank you for your reply.
I was aware that the OSERDESE3 was being translated from a ODDRE1 instance in the underlying code.  I didn't mention it, since my puzzlement involved only the OSERDESE3 instance.
This part your post appears to be key: "This is different than an OSERDESE3 in ODDR_MODE..."  It seems to me the difference you raise compels at least two separate types of ODDR_MODE operation for the OSERDESE3:
  1. When the OSERDESE3 is translated from an ODDRE1 instance, which causes the ODDR_MODE attribute to get set to TRUE, but the instance is clocked by the CLK pin--not by the CLKDIV pin--and
  2. When the OSERDESE3 is inferred from another source, which causes the ODDR_MODE attribute to get set to TRUE, but the instance is clocked by the CLKDIV pin, not by the CLK pin.
That is one tricky distinction.  My instant design appears to use the former type of operation.  The documentation seems to only cover the latter.
Thank you (and everyone) for the help.
amaheshwari
@jg_bds
This is a fairly old thread, but I got here so this may be helpful for someone else.
The statements
Seem to be incorrect.  The device in question is mentioned as (Zynq) UltraScale+ but the data sheet page cited is for UltraScale (not UltraScale+).  According to AR# 67261 (Clock Difference Between OSERDESE3 ODDR mode in UltraScale and UltraScale+ devices), "When performing the transformation from ODDR to OSERDESE3 in UltraScale and UltraScale+ devices, differing clocking results will be found in the implemented design. In UltraScale, the clock is connected to the OSERDESE3 CLKDIV port and in UltraScale+, the clock is connection to the OSERDESE3 CLK port."
