mduprez_mutest
OSERDES3.OQ routing to Fabric
Dear All,
For an instrumentation application, I am trying to have some FPGA output being driven by:
- Either an OSERDES3 output (Data rate 400Mbps, clocked by "clock_1")
- Either some other signal generated inside the Fabric, from another clock totaly asynchronuous from "clock_1"
(The switch from one to another is made out of some internal registers)
My past experience with V4, V5, V6 tells me that from the OSERDES output, I can only go to the ODELAY or to the IO. The only solution I am seing (not proven working yet) is using partial reconfiguration of the IO
I have however tried to do a small design with the above architecture (see implemented schematics below) and got the following message "dhi_sds_o Routable but not routed" with the following DRC status (impl_1_route_report_drc_0 - impl_1.rpt):
RTSTAT-1#1 Critical Warning
Unrouted nets
1 net(s) are unrouted. The problem bus(es) and/or net(s) are dhi_sds_o.
Related violations: <none>
(the dhi_sds_o net is the one in blue on the schematic)
unrouted netunrouted net
My question are the following:
1) "Routable but not routed" is a soft way to tell me that I am trying to do stupid things ?
2) does the connection OSERDES3.OQ to FPGA Fabric exist ?
3) If yes, can I do the routing manually or set some variable in the project switch such that the router will accept to route the wire ?
I have attached the .v for this attempt. I was running 2019.1., target is xcku060-ffva1517. Not able to attach the project xdc, so the few constraints are at the bottom
Thanks for your clarification
Mathieu
######## Start Constraint
set_property LOC BITSLICE_RX_TX_X2Y156 [get_cells {timing_gen_osds}]
set_property LOC SLICE_X96Y181 [get_cells {output_mux}]
set_property PACKAGE_PIN P18 [get_ports dhi_p]
######## Stop Constraint
pthakare
Hi @mduprez_mutest
OSERDES3.OQ i.e  datapath output of OSERDESE3 can only drive ODELAYE3 or IO . There is no dedicated routing or connection from OQ back to fabric.
pthakare
Hi @mduprez_mutest
