Problem with selecting the version of FPGA device
Hello.
I'm using Vivado 2018.2 and a KCU116 board which is equipped with Kintex UltraScale+ FPGA (xcku5p-ffvb676-2-e).
I'm trying to use the IDELAYE3.
In the generic map of IDELAYE3, there is a generic which is SIM_DEVICE as below code.
SIM_DEVICE =>       "ULTRASCALE_PLUS", -- Set the device version (ULTRASCALE, ULTRASCALE_PLUS, ULTRASCALE_PLUS_ES1, ULTRASCALE_PLUS_ES2)
My question is what is the device version of my device (xcku5p-ffvb676-2-e) ??
I couldn't find any document about it.
Thank you for your help.
Hi, @kimjaewon
Yes,  [ULTRASCALE_PLUS] is  right choice for you.
ES means engineering sample. The chips that used ES can be known by name like xczu9eg-ffvb1156-1-i-es1
@kimjaewon  Your part is part of Ultrascale+ family. So what you have as default for the SIM_DEVICE i.e. ULTRASCALE_PLUS is good.
Are you running into any issues?
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
@gnarahar
Thank you for your reply.
So your suggestion is that in my device,
ULTRASCALE_PLUS is the best choice other than
ULTRASCALE, ULTRASCALE_PLUS_ES1 and ULTRASCALE_PLUS_ES2?
Hi, @kimjaewon
