olupj
RFDC ADC simulation ... issue?
Simulating the RFDC with real input and mixing to Fs/4, -Fs/4.
Here's the config depiction:
In simulation when I start the real stimulus, Q leads I ( 4 samples / cycle) by 4 cycles. (Not showing start of active stimulus as it's about 335 cycles leading the AXI-S output). You can see where data output goes from static to 4 samples / cycle below.
I haven't analyzed it very much yet but this is a bit surprising.
And, just to show how IQ maps to AXI-S:
Has anyone experienced something similar? Xilinx - any opinion on what I am seeing here and why?
Thanks, best,
Jerry
olupj
Hi @pthakare so this might be a data - driven issue.
Resimulated yesterday, I got a 3 (12 sample) AXI-S lead on Q data vs I data.
Simulating today (modified stimulus on analog input), AXI-S I/Q data is aligned.
I'll test for that from this point forward (assertions)..
Thanks for the feedback.
Jerry
pthakare
Hi @olupj
Are you using example design testbench or your own testbench ?
Example design is generate using
Configure the IP as per your requirement -> right click and open example design .
The example design detailing is here
https://www.xilinx.com/support/documentation/ip_documentation/usp_rf_data_converter/v2_3/pg269-rf-data-converter.pdf -> Example design section
olupj
Hi @pthakare
That's my own testbench derived from the example testbench. I've ripped out the ADC sink to connect other DSP blocks.
As you mentioned it, I took a look at the Xilinx tb AXI-S interfaces and data does start consistently.:
However  I configured the system using the same calls in xilinx TB "call_setup_adc_config".
How would you recommend I pursue this? The system in the Xilinx TB and my TB are configured identically.
Jerry
olupj
Jerry
olupj
One other aspect that may drive that lag is that, thinking it through, using the coarse mixer the lag of 15 zeros (not 14 necessarily) might be reasonable given a 59 tap filter and using a DSP trick whereas the Q rail only sees the center tap and therefore has a half-filter lag. This doesn't explain the lag I see exactly, however, with FIR2 in the system.
