a4speaker
Voyager
Voyager
RFSoC ADC: covering 0 to Fs with 1 ADC
For FPGA chip on ZCU111 board, The ADC's datasheet says its analog bandwidth is 4 GHz. Datasheet of rfsoc IP says that we can use just 1 Nyquist zone at a time. To cover full bandwidth of 4 Ghz, we would need 2 ADCs (1 ADC for 0 to Fs/2 and other ADC for  Fs/2 to Fs).
My question is: Is there any other way of using ADC instead of rfsoc IP so that I can use full 0 to Fs range with 1 ADC?
klumsde
Normally you will know where the modulated signal is in the carrier. There is always an element of frequency planning.
You need to know which nyquist zone you are in ahead of time. this is needed for calibration.
You won't be able to just swap the nyquist zone on the fly at run time. the ADC will need to converge on it's calibration again so it won't seamlessly flip nyquist zones.
the capability to frequency hop in real time is coming in the 2018.3 release of the IP but again you will need to be in the one nyquist zone.
Keith
drjohnsmith
if your sampling at say 1 GHz,
first nyquest is 0 to 500 MHz ( minus a bit )
    second is 500 MHz to 1 Ghz ( minus a bit )
       the third is 1 GHz to 1500 Mhz etc etc
Nyquest zones by definition fold, around Fs /2.
By definition, you can not have signals in more than one nyquest zone.
https://www.analog.com/media/en/training-seminars/tutorials/MT-002.pdf
klumsde
Hi @a4speaker
This has been discussed at length here.
https://forums.xilinx.com/t5/UltraScale-Architecture/Nyquist-zones-in-RF-SoC-ADC/td-p/900140
Sampling theory dictates that the samples are repeated around FS/2 on the frequency spectrum.
As mentioned in that thread the RF ADC needs to know which nyquist zone you are in for it's calibration.
maybe you should explain where this requirement comes from.
What are you trying to sample?
a4speaker
Voyager
Voyager
This is a research based custom communication link which is based on frequency hopping. If we are doing IQ modulation, isn't full 0 to Fs range available? Do we have to reconfigure ADC to jump to alternate nyquist zones in this case? Can nyquist zones be switched at runtime?
klumsde
Keith
spann
Hi  Keith :
I want to ask some questions:
1.If my signal bandwidth is 500MHz, and sampling rate is 4Gbps.
 Can I  set RFSoC central frequency to 1/2 fs (2G Mhz)? Due to signal is across zone 1 and zone 2
The frequency range I can set is (2G-1/2BW) i.e. 0Mhz~ 1750Mhz and 2250Mhz~4000Mhz  ?
2.  The calibration mode 2 is around 1/2 fs +- 10%(1800Mhz~ 2200Mhz)  ,so my 500Mhz signal can't locate cross   two  calibration mode?(i.e. I just can  set central frequency  to 0Mhz~1800-250=1550MHz)
drjohnsmith
You need to read up on adc workings
try this
https://www.analog.com/media/en/training-seminars/design-handbooks/Data-Conversion-Handbook/Chapter2.pdf
page 27 onward is of interest, the nyquest theory and folding.
spann
Hi :
Thanks for your reply.
I know  nyquist theory and folding, but the issue is the signal is wide band signal , so it  may locate
across two nyquist zone . Should I prevent this situation ?
i.e. prevent  range  1/2fs -1/2BW ~1/2fs +1/2BW  ?
drjohnsmith
I have a problem with you saying you understand nyquist and folding, as that is what you are describing.
generally, you can not have a signal in more than one nyquest zone, you have to analog filter out any nyquest zones you do not want. There are exceptions for narrow band signals )..
e.g. if you have a signal in f0 to fs/2, you can not have a signal in fs/2 to fs.
