Jwilson
RFSoC GEN3 Nyquist zones
Wanted to double check that i am understanding this correctly, for the GEN3 RFSoC (ZU48DR) the sampling rate is 5.0GSPS and the analog input bandwidth is 6GHz. So the first Nyquist zone is 0-2.5GHz, the second Nyquist zone is 2.5-5.0GHz and the third Nyquist zone is 5.0-7.5GHz. Since the analog input bandwidth is limited to 6.0GHz we won't be able to operate in the third Nyquist zone entirely but will be limited to 5.0-6.0GHz. I have seen a lot of Nyquist related questions in the forums already for the GEN1 and GEN2 parts, it seems like you need to tell the RFSoC which zone you are operating in, for GEN3 does this exist still and is there a 3rd Nyquist zone option?
pthakare
Hi @Jwilson
Yes ,  3rd Nyquist zone can also be used upto signal meets the RF-ADC input bandwidth requirements. Zones 1, 3, 5, ... are referred to as odd zones, and zones 2, 4, ... are referred to as even zones.
In IP or using APIs 1 corresponds to odd Nyquist zones and 2 corresponds to even nyquist zones
Reply if you have any queries, give kudos and accept as solution
pthakare
Hi @Jwilson
klumsde
Hi @Jwilson @pthakare
Remember that you set this in the IP
But what this really does is for ADC it defines the location of the bulk of the signal power for the ADC calibration
For a DAC setting the Nyquist Zone defines if the DAC is in Mixed mode or not
Keith
